p0300 code - Nissan Forums : Nissan Forum
Old 04-23-2005, 03:14 AM
p0300 code
My girlfriends 2000 altima was checked by autozone with the code p0300. I've changed the plugs and wires so far. Nothing different. I've searched the forums here and googled with no clear answer on what to do. Autozone said fuel injectors, so I bought techtron. Is he right? Will it work? What else can I do? Replace injectors? I've searched the forums but nothing clear on what to look for or replace. Any help is greatly appreciated
Old 04-23-2005, 03:25 AM
Am I still a NOOB?
don't ever listen to what autozone tells you. I used to work for them and the most of them are idiots. Take down the information given to you from the scanner and take it to a shop and ask them. But the thing is, all they can do is guess without being able to diagnose it. So the best thing you can do is take it to a shop and give them the scanner readout which might help them in diagnosing it, but I'm sure they'll have their own scanner anyway.
Originally posted by Jus4Sho
If you GOT nothing to LIVE for, FIND something WORTH LIVING for.
SHIFT_Manually
Old 04-23-2005, 04:01 PM
The Don.
P0300 means a multiple cylinder misfire. This is usually because of intake manifold leaks. Listen to the exhaust pipe sounds. Place a piece of cardboard at the exhaust to listen better to the sound. The sound should be consistent which no change. Otherwise, you have a mifiring going on somewhere.
ITEMS FOR SALE
Old 05-22-2005, 01:45 PM
The cause was intake manifold gasket. I took it to a nissan dealer
