How long does it take to replace the radiator fan motor? - Nissan Forums : Nissan Forum
post #1 of 8 Old 07-24-2005, 08:01 AM Thread Starter
The passenger side radiator fan does not work. The fuses, relays, and sensor are all good. Also, the driver side fan works well. I check Kragen, autozone, and online nissanpartstore and only find the whole fan assembly with both fans for about $143. This assembly is also on ebay for $97.5 + $20 shipping.
So I get a few questions here:
1. With only the driver side fan working, the coolant tempature is always very good (40% of the High) even in the hot summer with A/C on. It seems that Altima's cooling design is so good that one fan is enough to prevent engine overheating. So, is it necessary to fix this problem?
2. Where can I find the passenger side fan motor for a cheaper price? Is there any universal fan motor on the market?
3. How long does it take to replace the fan assambly? Is it a time-consuming work? I am wondering whether removing the radiator hoses and draining the coolant are required for this job.
Thanks for your suggestions.
1998 Nissan Altima SE 5-speed fully loaded
136,000 miles
everything stock except Kyb-GR2 struts
andyucd is offline
post #2 of 8 Old 07-24-2005, 09:20 AM
Erect Member
Asleep's Avatar
Quoted: 10 Post(s)
iTrader: 6 reviews
i dont think both of my fans ever come on unless im running the a/c. even so, without the a/c, ive left my car in the driveway running for 45 minutes before to see if the fans would kick on. waste of time - they never did. replace them to be safe. its only about a 10 minute job.
Asleep is offline
post #3 of 8 Old 07-24-2005, 12:01 PM
Ace
Rockin the Kasbah
Ace's Avatar
Even when I was boosting, the fans were never on that often...I'd notice it when timing the car after driving that they would come on for some seconds and then turn off....
But def look into your AC...Asleep Altima basically said what I was going to about that part...
97 240 - SR Power - 400whp
365th EN - OIF 3+4
Turbo Altima
Ace is offline
post #4 of 8 Old 07-24-2005, 12:32 PM Thread Starter
Thanks for your suggestions. When the A/C is turned on, the passenger side fan does not work at all. Maybe it is time for me to replace it.
I bought this car in Dec 2004 and did not inspect the fans carefully
136,000 miles
andyucd is offline
post #5 of 8 Old 07-24-2005, 02:32 PM Thread Starter
I just remove the fan assembly from the car. The passenger side fan motor is dead. When I shake it, I can even hear the rattling sound of the broken parts inside this dead motor.
But I cannot fine ONE fan motor on the market. The fan assembly including two fans costs more than $100. Where can I find just one fan motor? Otherwise, do fan motors from other cars (accord, camry, civic, sentra, etc) fit our altimas?
136,000 miles
andyucd is offline
post #6 of 8 Old 07-24-2005, 05:52 PM
you cant find a junk yard with a car that has that?
Devil Man is offline
post #7 of 8 Old 07-25-2005, 08:34 AM
Ace
Rockin the Kasbah
Ace's Avatar
I woudl just replace the entireassembly with a junk yard unit...can be found for 40 or less usually....
365th EN - OIF 3+4
Turbo Altima
Ace is offline
post #8 of 8 Old 07-27-2005, 12:27 AM Thread Starter
I only found a 96 altima's fan assembly, but the electric connector does not fit. It will take some time to find a 2nd generation altima around the town.
So I just ordered a set of brand new assembly from ebay. $97.5 + $19.95 shipping - $5off ebay coupon - 1% credit card cash back. $111 shipped to my door. I will install it in this week.
It seems that this assembly is exactly the same as the Kragen's and mechanics' parts ($148 + tax or even more).
136,000 miles
andyucd is offline
