High Beams Don't Work - Nissan Forums : Nissan Forum
post #1 of 18 Old 08-06-2006, 05:09 AM Thread Starter
This problem started about 2 weeks ago and whenever I'm driving at night w/ my lights on, if I switch it to the high beams(either thru pushing the control thing forward to lock them on or pulling it to temporarily put them on), the low beams go out just like they should but the high beams don't come on at all so I'm left with no visibility in front of me. I checked the fuses next to the battery for the high beams and they are still working. I'm pretty much ruling out that both high beam bulbs or harnesses went out at precisely the same time because I don't think that is likely at all. Any ideas what I should do next to fix this problem? Thanks in advance.
-'99 5-speed Altima
Performance Mods: Hotshot CAI; Stillen 4-1 Header; OBX Catback Exhaust - Hiroshima Style; Vibrant Front Strut Tower Bar; S.T. Rear Anti-Sway Bar; Taz's Motor Mount Inserts
Audio Mods: Pioneer Head Unit; 4x60 watt Infinity 6200i 2-ways; Infinity Kappa Perfect 12.1 sub w/ Kenwood Amp
-1990 300ZX 2+2
Mods: Intake, headers, lightweight flywheel, RPS sport clutch, lightweight drive shaft, ECU, JWT S1 Cams, anti-sway bars, short shifter...203 rwHP
NissanEnthusiast007 is offline
post #2 of 18 Old 08-06-2006, 06:55 AM
Spicey rice!
mcgunit77's Avatar
we have two filaments in the bulbs, check the bulbs because the the high beam filament is pry burnt up, time to get some new ones..make sure there nice ones too this time
mcgunit77 is offline
post #3 of 18 Old 08-06-2006, 07:43 PM Thread Starter
Ok thanks, I'll check those. Any recommendations on replacement headlights that may be better than OEM but not crazy bright or way too expensive? Thanks.
-'99 5-speed Altima
-1990 300ZX 2+2
post #4 of 18 Old 08-06-2006, 08:20 PM
Rockin the Le Bra
Tex93Altima's Avatar
id shell out the 40 or so dollars for some silverstars. theyre kinda pricey, but theyre worth it. everything on the road will be much clearer for you.
The alty is no more
icy day in austin...
Tex93Altima is offline
post #5 of 18 Old 08-06-2006, 08:22 PM Thread Starter
Do the Silverstars require an adaptor harness of any sort or will they simply plug and play?
-'99 5-speed Altima
-1990 300ZX 2+2
post #6 of 18 Old 08-06-2006, 08:24 PM
Rockin the Le Bra
plug and play...theyre stock wattage so no upgrade harnesses required. ive had mine for about 3 years with no problems.
The alty is no more
post #7 of 18 Old 08-06-2006, 08:55 PM Thread Starter
Thanks a lot. I'm gonna go buy some now.
-'99 5-speed Altima
-1990 300ZX 2+2
post #8 of 18 Old 08-07-2006, 03:22 PM
did they both go out at once??? to me sounds like a headlight switch...
SPEEDO is offline
post #9 of 18 Old 08-07-2006, 03:39 PM
Our 2nd gens take bulb # 9007 you can get them anywhere , they even sell
them at my local walmart. Yes they are plug and play .
Glenn
1998 ALTIMA GLE , CS3 Brushed Pewter
Gone But Not Forgotten TOTALED
RIP 4/28/08
Hello 2009 Toyota Camry SE.
Glenn14 is offline
post #10 of 18 Old 08-07-2006, 04:34 PM Thread Starter
Yeah, they took roughly 2 minutes to install and work great. Thanks guys.
-'99 5-speed Altima
-1990 300ZX 2+2
post #11 of 18 Old 03-27-2013, 02:00 AM
And I believe the current comes from your passengers side of the car and continues to the drivers side headlight. So if the power is interrupted before your pass side light it won't continue to your dr. Side light. So look behind your pass. Light for any bad connectors. Get test light and with car on and switch activating your high beams see if you got power into your fuse box located next to your radiator overflow canister. If you got power on both sides of the fuse your problem is now between fuse box and headlight. Check it out. Gl
"INKMAN1108"
Inkman1108 is offline
post #12 of 18 Old 03-27-2013, 05:19 PM
Spontaneous Parts Vendor
If you got SilverStar Ultras, save your receipts. If you are lucky they will burn out before the warranty expires. I tried them once, they lasted one year and two weeks (low beams burnt out in both bulbs, within two days of each other) Of course they have a one year warranty.
Regular Silver Stars last pretty much forever. Don't know what the reason for the difference in lifespan is.
Guy de Loimbard is offline
post #13 of 18 Old 03-27-2013, 07:47 PM
Carbon Meet Amber
StanzaDescendant's Avatar
Quoted: 1 Post(s)
To create more lumens the heat is increased. Increased heat means a shortened bulb life. The same thing when HID bulbs are boosted over 35w.
And agreed on SilverStar's being junk.
Originally Posted by cthunder
FX-R Projector Retro v3.0
ES Fog Retro v2.0
DIY Trunk/Chassis Bracing
StanzaDescendant is offline
post #14 of 18 Old 03-27-2013, 10:46 PM
With H.I.D lights being so inexpensive now I just try to order the highest quality set for the best price. I stay away from the real cheap ones. You get what you pay for!! I've had sets go in a few days and I've had a set in my Acura for two years now. No problems!!!
"INKMAN1108"
post #15 of 18 Old 03-28-2013, 03:20 AM
Carbon Meet Amber
Quoted: 1 Post(s)
Real HID still isn't that cheap. Aftermarket on the other hand. . .
My current setup is using Osram CBI's which retail for ~$185, plus the projectors, ~$120, associated harnesses and shrouds, $45, and aftermarket ballasts, $120. My Matsushita ballasts that I had potted I got for a steal during a sale but I believe TRS usually sells them for ~$160 or so.
Now if you go cheap aftermarket, (eBay/DDM/VVME, etc) you're looking at $40 for ballasts and bulbs.
Which do you think will function better? The $40 kit that somehow they're making profit on, even after warranties. Or the OE kit that meets or exceeds manufacturer specs?
ES Fog Retro v2.0
