Famous P0325 Knock sensor malfunction.... - Nissan Forums : Nissan Forum
Old 11-08-2006, 12:19 AM
Wsup everyone, i got these codes pulled today at autozone.
P0325 knock sensor 1 circuit malfunction bank 1 or 1 sensor and
P0440 Evap emission control system malfunction.
The sales guy mentioned that they might be from a loose gas cap and sure enough it was loose when i checked (this is my girl's 99 altima SE with 103k miles). so my questions is how can i clear the check engine light. thanks everyone and this is an awesome forum.
Old 11-08-2006, 03:34 AM
knock
I had the po325 and it was a bad sensor. Now with a new one the engine shows more power.
Old 11-08-2006, 05:49 AM
Still Learning....
Sounds like you have to replace this sensor and i have heard its a pretty difficult job.
Check your EGR Valuve to see if you have press down on the diaphram as thats what could be triggering the CEL. Also check the EVAP Canister too and the tubes for damage ect.
Hope this helps in some way.
A more knowledgable Altima owner will respond soon for you though
RIP Altima 97 Altima GXE-
OEM Spoiler
93 Grille
Pioneer CD Player
FSTB
KYB GR 2 Shocks, KYB Mounts, KYB Boots
Hello 02 Sentra SER-
Pioneer CD Player
Euro Style Antenna
Greddy Shift Knob
New Project-
1985 Volvo 760 Turbo
Old 11-08-2006, 06:32 AM
This was discussed recently....
However, changing it out can be very time consuming if you try to get at it the usual way. And most places will charge you anywhere between $150 - $300 just to change the sensor. And the damn part costs more than $150 itself.
Anyway, here's a link to how I changed mine out:
http://www.nissanclub.com/forums/gen...ml#post3034978
As for clearing the CEL, take the car back to Autozone and they will do that. Only change the knock sensor if the code comes back in a couple of days/weeks. It may or may not turn the CEL on - different models/years seem to have different experiences with this. So you should get the codes pulled in a couple of weeks even if the CEL does not come on.
Hope all this helps.
'95 Altima GXE
ST RSB
O-R FSTB
AT GK
Old 11-08-2006, 04:28 PM
bkal's Avatar
You can pull the negative battery terminal and leave it off for 24 hours, that will reset the ECM.
1995 Altima GXE (sold)
2002 Subaru Impreza WRX
2001 Yamaha YZF600R
Old 11-08-2006, 04:49 PM
Dark's Avatar
shift_Subaru
or you can do it the easy way by turning the screw on the side of the ecu... search for it, ive written it about 20 times by now...
1994 Altima GXE - Auto
Sold 9-15-07
2003 Toyota Echo 2dr - Auto
Given away 8-20-09
1998 Subaru Legacy GT Sedan - 5spd
2.2L Motor Swap
New 2.5 5spd Transmission
Outback Front Bumper Swap
2002 Legacy GT Black Leather Front Seats
Borla Rep Headers
2.5" Exhaust
Old 11-08-2006, 07:45 PM
Thanks for the replies guy's.
I am thinking that since it the code came up because the gas cap was loose, I will have it reset and see if it comes back again before replacing it. btw am in the south shore MA area if there are others near me. laterz
