adjust headlight for 2001 altima - Nissan Forums : Nissan Forum
post #1 of 5 Old 11-25-2006, 07:53 AM Thread Starter
I want to ask, how to adjust the angle of the light (up and down) ?
Do i have to remove anything?
rickyleung is offline
post #2 of 5 Old 11-26-2006, 01:23 AM
jban4US's Avatar
do you have your owner's manual? it tells you how in there.
jban4US is offline
post #3 of 5 Old 11-26-2006, 05:14 AM Thread Starter
I don;t have the owner manual >___<
post #4 of 5 Old 11-26-2006, 06:50 PM
Another User
nisaltimo's Avatar
apparently i'm an idiot
nisaltimo is offline
post #5 of 5 Old 11-27-2006, 05:01 PM
I keep em comin back.....
BLACK SE's Avatar
Quoted: 1 Post(s)
DO NOT touch that bolt that sticks out from the headlight, that is pre-adjusted from the factory for the left and right angles, they did this for the simple reason of you not effin it up and blinding on-coming traffic.
The adjuster is on the furthest to the left closest to the fenderwall (left lamp) and the same for the right lamp. You will need a phillips screwdriver and you will need to remove the coolant tank unless you have abnormally small hands, move the bolt to your left (clockwise) to raise the bubble surrounding the bulb, and counter to lower it, keep doing this until you see the light on the wall aimed to where you would like for it to be.
BLACK SE is offline
