ecu is in fail safe mode....help!!!!!!!!!!!!!!!! - Nissan Forums : Nissan Forum
post #1 of 10 Old 02-07-2007, 01:30 PM Thread Starter
car is stuck in third,ecu is giving a speed sensor malfunction code,but i was told that it is because the ecu is in a fail safe mode and check engine light is on and o/d won,t work!!!!!!!!!!!!!!!!!!!
tontee is offline
post #2 of 10 Old 02-07-2007, 03:17 PM
shift_Subaru
Dark's Avatar
well id sincerely doubt od would work... it sounds to me like you need to have a tranny shop take a look at that bish. you can try resetting the ecu via the screw on the side of it... for more info search
1994 Altima GXE - Auto
Sold 9-15-07
2003 Toyota Echo 2dr - Auto
Given away 8-20-09
1998 Subaru Legacy GT Sedan - 5spd
2.2L Motor Swap
New 2.5 5spd Transmission
Outback Front Bumper Swap
2002 Legacy GT Black Leather Front Seats
Borla Rep Headers
2.5" Exhaust
Dark is offline
post #3 of 10 Old 02-07-2007, 03:19 PM
Speed sensor goes to the speedo first then the ECM. It's either the sensor, the wiring, or the speedo. Have you been playing with the dashboard?
kenshi is offline
post #4 of 10 Old 02-07-2007, 05:06 PM
Yeah, I spelled it wrong
Atimadator's Avatar
Pull the trans fuse for a few mintues and put it back it. I have done that before and working fine after.
Atimadator is offline
post #5 of 10 Old 02-07-2007, 06:13 PM
The Don.
Quoted: 5 Post(s)
I concur.
'94 Nissan Altima SE, 5spd.
ITEMS FOR SALE
jserrano is offline
post #6 of 10 Old 02-11-2007, 03:10 AM Thread Starter
yes i had took the dash out to have it painted and when it was put back in is when i had the problems and i changed the cluster out already and still getting the fail safe mode.
tontee is offline
post #7 of 10 Old 02-11-2007, 03:13 AM Thread Starter
where is the trans fuse located.thanks
tontee is offline
post #8 of 10 Old 02-11-2007, 03:19 AM
93 GLSE Auto
does your speedo work at all?
Ace
2002 Maxima SE 6 Speed hlsd
1993 Altima SE Auto
realeztace is offline
post #9 of 10 Old 02-11-2007, 04:52 AM Thread Starter
yes my speedo works but the pass side window and door lock don't work along with the defroster switch,o/d,pass side power mirror,and cruise does'nt work..checked all the fuses under the dash all are good...thanks
tontee is offline
post #10 of 10 Old 02-11-2007, 12:55 PM
93 GLSE Auto
i would say you forgot to plug in some harness or pulled on the harness so bad the wires came out... good luck get a multi meter and start there
Ace
1993 Altima SE Auto
