Old 02-09-2007, 06:06 PM
The Don.
DEPO Fog Lights for 1st Gen
I am planning of getting the DEPO headlights and turn signal light. But, are there any DEPO fog lights available for the 1st Gen? How does it look? I really like the look of the OEM fog lights but was wondering if there is anything of better quality and higher output. I couldn't locate anything on the DEPO so far. TIA.
ITEMS FOR SALE
Old 02-09-2007, 10:38 PM
93 GLSE Auto
i believe i once saw just the replacement lens for oem wich was a lot clearer dont remember the company but its out there
Ace
F\S : Stock SE struts and springs, AC Compressor, 94 Rack and pinion, Sunroof switches, Power Window Amps, All 4 door harnesses, blue inside door handles, Stock radio brackets with cup holder, Grey 6.5 inch speaker rear deck, Stock Fog light stalk, motormight brand new dist, stock headlights, stock turn signals, Manual heater controls, Few need painting se rims, New 93 to 97 Driver Side Fender
Old 02-10-2007, 04:08 PM
StealthyAltima
I just bought aftermarket fogs. They are projector lense with h3 bulbs...and they are yellow with my blue headlights looks sweet. IS300 look. If the bulbs aren't high enough output for you then you can just upgrade the h3 bulb...to HID if you relaly want
1997 Nissan Altima GXE
-SE Sides
-Red Painted Valve Cover
-06' Spec-V Wheels
-205/40/17 Nexen N3000 Tires
-Zenn Suspension 2" Lowering Springs
-Bomz WAI
-Tsudo Catback Exhaust
-High Output Headlight Bulbs
-OBX 4-2-1 Header
-Taz's Street MMI's
-UR Pulley
-a/f, volt, vacuum gauges
Old 02-10-2007, 05:48 PM
Jesus's Avatar
Burning Up
I've wanted these for a while now, and I have always been pushing the idea to Depo :P
Last I heard though Depo wasn't going to make the fog lights.
1994 Nissan Altima SE
1974 Datsun 260Z
Old 02-10-2007, 09:42 PM
altim8victory's Avatar
grocery getter....remixed
Ive been looking also for a long time and cant find any company that makes them. I bought aftermarket ones that are exact matches to ours made by TYC and put them in with h3 HID's the light output is sick....let me know if you want me to take pics to show you how they look you might like it.
Old 02-10-2007, 09:58 PM
Jesus's Avatar
Burning Up
pics please
Old 02-10-2007, 11:30 PM
The Don.
I had also replaced my original one with a set of TYC and SilverStar bulbs. The light output was better that original but not the greatest. Now one of the glass is shattered and the other has too many dings. I could order another set of TYC and would contemplate on the H3 HID you are talking about. Yes, get us some pictures. That might be a better option. Thanks.
Old 02-11-2007, 04:08 AM
93 GLSE Auto
93 GLSE Auto
1993 NISSAN ALTIMA SE 2.4L 2389cc L4 MFI (B) [KA24DE] Fog Lamp Lens
Old 02-11-2007, 07:57 AM
Hey J here you go Im not great with a camera but these should give you an idea of the what output is with HID's......this is a 6500K kit and keep in mind the car is facing on a downward angle in the driveway.
VIEW FROM 8FEET
VIEW FROM ACROSS THE ST ABOUT 30-40FT
VIEW WITH 8000K HEADLIGHT HID & 6500K FOG
NEXT TO THE CAR
VIEW FROM INSIDE THE CAR
Old 02-12-2007, 02:33 AM
BoostRevolution's Avatar
I can get the foglights for a good price if I get enough interest in them....
Parts 4 Sale
96 Altima GXE 5spd - R.I.P. 3/1/07
- 01 Tranny
- Fidanza Flywheel
- Spec 6puck clutch
- Nismo muffler
- Grounding kit
- Intake
99 Altima SE Autotragic
- Stillen Header
- Intake
- 2.5 header back exhaust with forza muffler
- Fidanza Flywheel
- Spec 6puck clutch
- Zenn Springs on Tokico blues
- 93 5spd tranny swap
- 01 motor swap
- 85 shot NOS
- 440cc injectors w/ project nissan rail
Old 02-12-2007, 07:52 PM
chinabean's Avatar
i need to get em already god damn..i don't know what the heck you guys are talking about with hid's and all those numbers and whatnot..
Old 02-12-2007, 08:37 PM
HID kits are usually measured in comparison to natural white light from the sun in Kelvin degrees. Natural sunlight at noon is 4870 degrees K. Light produced by a HID xenon bulb is 4100 degrees K. Light from a standard halogen bulb is 3200 degrees K, and from an ordinary incandescent bulb is 2800 degrees K. The lower the temperature rating, the more yellowish the light appears. The more you increase in kelvin degrees the more intense the light and color. So we dont get confused ,for correct fitment/replacement of the kits they usually carry the same bulb code hence why the foglight kit on on a 1st gen is an H3 type bulb.
Old 02-12-2007, 09:26 PM
The Don.
Thanks altim8victory. I'm going to have to get a HID kit for the fog lights. Those look too sweet. I've heard (read) there are shields available for locating the light beam towards the ground. Have you heard of this for fog lights?
BoostRevolution: What manufacturer of fog lights are you talking about? How much?
EDIT: My DEPO headlights and turn signal lights are on their way, Thanks Xtremelights.
Old 02-12-2007, 10:11 PM
Well the aftermarket and even the stock fogs have that shield built into them to keep the light back towards the mirrored reflector in the light housing. Ive heard of the shields as well but there usually used on larger metal hallide light housings (Street/parking lot lamps), and also for DIY conference room projectors and to get one that fits correctly maybe a little hard to find plus you would have to bake the fog to open it up too much work IMO...Why not just adjust the angle of fog housing itself?
