Siphon gas?!? - Nissan Forums : Nissan Forum
post #1 of 16 Old 05-10-2007, 12:29 PM Thread Starter
bling2bling13's Avatar
Siphon gas?!?
Hello, Well the 97 altima has been sitting for 8 months getting a massive overhaul and i finally took her out for the first time this past weekend and filled her up with gas. I am attending Hot Import Nights (Philadelphia) tomorrow and in the facility you can only have less then 1/4 tank of gas! I tried all the regualar methods of siphoning the gas out but i was un successful. I also used a minature fuel pump that works great but was unable to pump the gas out. I figured im just not getting the tube into the actual tank. i had enough line to go into the tank but i could only get a small stream out for a couple seconds. Is there any kind of screen that blocks a tube from entering the tank? Is there any other methods or pipes i can disconnect to drain this fuel?
bling2bling13 is offline
post #2 of 16 Old 05-10-2007, 02:28 PM
naveed2126's Avatar
Gas is so expensive these days... I'll take what you don't want, lol jk. Just find another way of getting there or burn off the gas to 1/4 tank. Besides, do they really check to see what you've got?
naveed2126 is offline
post #3 of 16 Old 05-10-2007, 02:32 PM
bkal's Avatar
What I had to do was take off the filler hose from the tank, then insert your siphon hose directly into the tank. I think there's some kind of anti-siphon protection. It's work, you'll most likely have to try multiple times because of the bends in the tank.
1995 Altima GXE (sold)
2002 Subaru Impreza WRX
2001 Yamaha YZF600R
bkal is offline
post #4 of 16 Old 05-10-2007, 02:42 PM Thread Starter
damn i figured it wasnt going to be easy. I was thinking about letting the car run all night, but im sure thats not good for the motor.
post #5 of 16 Old 05-10-2007, 02:49 PM
enlighten me
johnmann's Avatar
It might be easier to tap into the line at the fuel filter under the hood. Connect the siphon hose onto the end of it, then turn the car on and let your fuel pump run it out. Just an idea...
johnmann is offline
post #6 of 16 Old 05-10-2007, 03:11 PM
que es un altima?
There's an access cover to the tank under the rear seat bottom. You take that cover off and the fuel pump and that should give you plenty of room to pump the gas out.
booyah_tribe is offline
post #7 of 16 Old 05-10-2007, 03:36 PM Thread Starter
I tried this as well last nite, but the fuel pump only runs for 5 seconds before it is expected to start. i would have to turn the accessory on like 100000 times and im sure thats not good for the ignition as well as all other electropnic parts to be turned on and off that many times.
post #8 of 16 Old 05-10-2007, 03:37 PM Thread Starter
I saw the cover but havent cracked it open yet. Will i have to take out the fuel pump to access the gas? or can i work around it?
post #9 of 16 Old 05-10-2007, 06:11 PM
Offline
danny_ka's Avatar
jump the fuel pump harness 12v and it will pump constantly
540/390@26.5psi
11.1@137 letting off at 4th
danny_ka is offline
post #10 of 16 Old 05-10-2007, 07:17 PM
ACN
Ther should be a drain plug under ur tank just take the plug out and drain ur gas
Decals add hourse power!
ACN is offline
post #11 of 16 Old 05-10-2007, 08:42 PM
que es un altima?
Here's what the fuel pump setup looks like. You'll have to remove it to actually see the gas in the tank.
post #12 of 16 Old 05-10-2007, 09:12 PM
Yeah, my moms 95 has a white drain plug. Right at the back
fuzzy03CLS is offline
post #13 of 16 Old 05-11-2007, 12:20 PM Thread Starter
Im goign to try to locate the drain plug first before i jump the fuel pump. I gave a quick glance before at the tank and i didnt see a drain plug. Maybe i missed it but does every first gen tank have one?
post #14 of 16 Old 05-11-2007, 02:07 PM
jdm
altima420's Avatar
just take your dash apart and set the needle at 1/4 then fill it up after and set it back... quickest way I can think of..and way easier
altima420 is offline
post #15 of 16 Old 05-11-2007, 02:26 PM
bkal's Avatar
or just disconnect the plug for that section of the dashboard. It's not like it's going to be on.
or unplug the fuel gauge wire from the fuel pump/sending unit.
Check out the FSM in my sig for which wire you need to disconnect.
2001 Yamaha YZF600R
bkal is offline
