help with radio reception 01 altima - Nissan Forums : Nissan Forum
post #1 of 5 Old 05-22-2007, 08:32 PM Thread Starter
i have a 2001 altima gxe. the antenna for the radio is located in the back window where the rear defroster lines are. I have horrible radio reception. I called the dealer to ask what i can do about this or if its a common problem and they told me that the antenna is probably disconnected. they said that it runs under the seat somewhere and i needed to plug it back in. i cant figure out where the antenna runs from the window. does anyone know how to fix this or where i should look?
xourmysunshinexo is offline
post #2 of 5 Old 05-22-2007, 08:58 PM
remove the rear right panel and first locate the antenna...its a black module...with 2 wires coming out of it....
Now start following those wires back to your HU...
mavster is offline
post #3 of 5 Old 05-22-2007, 09:37 PM
The Don.
Quoted: 5 Post(s)
Quickie tech talk for the uninhibited,
Many car stereo receivers uses two antennas for something called diversity reception or multipath reception. What that means that that two antennas receives the signal through multiple paths. You can think of it like echo receptions on two antennas.
With only one antenna working, you could be feeding a weak signal to the radio and the station would drop out due to signal/noise ratios. Some radios have better S/N ratios and can overcome this weakness. In yet some better cases, one antenna would cause radio stations to come in and out, called fading.
Assuming that the receiver's tuner section is not bad then you are likely running off just one antenna. In the '01, you have the rear window antenna with a terminal plugged into it that feeds to one side in the back of the receiver. And you have a separate antenna amplifier, instead of a power antenna, which is located in the inside the passenger side rear pillar, and that feeds another section of the receiver. This wire feeds through the passenger side headliner up to the rear of the receiver.
What I would probably have done in you case is remove the receiver and connect a separate wire to one of the two antenna inputs. If the reception improves then troubleshoot that antenna section. If it still doesn't work, then try the same trick on the other antenna. If neither work then you probably have a problem in the receiver.
'94 Nissan Altima SE, 5spd.
ITEMS FOR SALE
jserrano is offline
post #4 of 5 Old 05-23-2007, 02:13 PM Thread Starter
thanks.. im going to try today.
post #5 of 5 Old 04-02-2008, 06:54 PM
hey man i have the same problem same car i did not call the dealer if you look at the rear window on the right side of the car is where the antenna on the window gets hooked up into a module u need to to take of the rear piller the wire from there goes in to the head liner and gets to the head unit through that but i cant figure it out nether see for me it only gets good reception when i open one of the doors to a specific degree like an inch out and receptions good closed non.
Altimas For Life is offline
