brake light wont turn off - Nissan Forums : Nissan Forum
Old 05-31-2007, 03:14 AM
ugly altima is ugly
brake lights wont turn off when i have the car on or off. i ended up having to pull out the fuse. does anybody know what could be the cause? thanks for the help.
Old 05-31-2007, 04:43 AM
Still Learning....
Look under your dash by the break pedal. Theres a little button that activates the brake lights when you press down on the brakes. See if that button needs to be fixed. Its probably stuck.
RIP Altima 97 Altima GXE-
OEM Spoiler
93 Grille
Pioneer CD Player
FSTB
KYB GR 2 Shocks, KYB Mounts, KYB Boots
Hello 02 Sentra SER-
Pioneer CD Player
Euro Style Antenna
Greddy Shift Knob
New Project-
1985 Volvo 760 Turbo
Old 05-31-2007, 06:01 AM
ugly altima is ugly
pressing the button does nothing.
Old 05-31-2007, 06:20 AM
what hes trying to say is
on the pedal assembly, there is a small hole that a hard plastic insert goes into.
when there is no pressure on the pedal, it is pressing the button in. when you press the pedal down, the switch no longer touches the plastic piece.
when that plastic piece disintegrates (which all nissans do) the switch can no longer be turned off.
that is your problem.
Old 05-31-2007, 02:37 PM
ugly altima is ugly
now that we know the problem, what is the solution? obviously the piece needs to be replaced but what is the piece actually called? thanks for the help guys.
Old 05-31-2007, 04:25 PM
The Don.
For $1.50, it is called a Rubber Stopper and the part # is 46584-S0100. Aren't you glad you asked?
ITEMS FOR SALE
Old 05-31-2007, 08:51 PM
ugly altima is ugly
I replaced the little rubber peice that presses against the brake switch but the lights still stay on. Is the brake switch the defective part? Do I need to replace it? I also found alot of broken little black peices of broken rubber/plastic. They dont match the rubber stopper I just got. Is there something else that could be causing the problem?
Old 05-31-2007, 09:03 PM
ugly altima is ugly
Nevermind, I figured it out. It was 2 rubber peices. Thanks for the help guys.
Old 07-17-2008, 04:18 PM
rmansaram's Avatar
I have the same problem, were you able to fix it? I manually push down on the switch and it does not turn off the light. I remove the switch and the lights are still on. Any ideas?
Old 07-18-2008, 05:37 PM
ugly altima is ugly
well seeing as it a year ago i sure hope i figured it out haha. i dont even have the car anymore but lemme try to help you out anyways. ifi you're just pressing one of the switches the brake light wont go off because you have to press both of the pressure switches back there. i didnt realize that both my rubber pieces were gone and it wasnt enough to replace just one.
3/29/08 rip 95 GXE
Old 07-18-2008, 06:19 PM
rmansaram's Avatar
Thanks, As I am reading other treads, I figure out I have 2 switch one for crusie control and one for brake. I only saw one and thats the one I was messing with. I think its the crusie control sw i was messing with, thats why nothing happen. I'll try again this afternoon.
Old 06-25-2010, 12:20 AM
Rover's Avatar
Fun2Drive
Question Brake Pedal Rubber Stopper 46584-S0100
My cruise control on my '95 Altima stopped working a month or so ago.
Then, the other day, the brake lights stayed on, and I found the tell-tale rubber tip on the floor mat. I had found something similar around the time the cruise control stopped working, but I didn't have clue as what that was, and tossed the tip of the rubber stopper.
The guys at the Nissan Parts desk said "would you like a green rubber stopper or a white one". I chose the white one, and I'm glad I did, because, based on what I've read, the green rubber stopper is for the clutch pedal, and I drive an Automatic.
The Part Number sold to me was the 46584-SO100, now for just $2.24 each, plus tax.
Now, I have a question..... to install the rubber stoppers for the the brake and the cruise control, do I just push in the brake pedal hard, and then push the rubber stopper in the hole ? ? ?
I would think the rubber stoppers could be installed without unbolting anything.
Old 07-01-2010, 12:07 AM
Rover's Avatar
Fun2Drive
Smile
The solution was to position the rubber stopper over the hole, and then allow the brake pedal closing back down to push the stopper in.
