Manual Transmission Fluid - Nissan Forums : Nissan Forum
post #1 of 11 Old 06-03-2007, 08:20 PM Thread Starter
cfelicio's Avatar
Hello There!
Today I decided to replace my transmission fluid (manual), so I bought 5 qts of red line mt-90 (my previous fluid was lucas 75w90, GL-5).
So, I jack the car up, unbolt the drain bolt (at least I thought it was hehe), and let it drain).
Now, I think I removed the wrong bolt because:
1 - Only 3.5 qts came out, as I learned by refilling it.
2 - A small spring and a metal ball came out on the oil
Question:
Will my transmission die for mixing fluids? What is this small spring and ball supposed used for?
cfelicio is offline
post #2 of 11 Old 06-03-2007, 09:06 PM Thread Starter
cfelicio's Avatar
Pictures to illustrate!
The hole I used to fill / drain:
The hole I think is the correct one (duh):
The spring/ball that came out:
cfelicio is offline
post #3 of 11 Old 06-03-2007, 09:27 PM
You'd lose.
CvlEngAltima's Avatar
The spring and bearing look like a part to a check-valve. Specific pressure causes the bearing to compress the spring and let whatever fluid through.
1999 Firebird Formula Trans Am WS.9, M6, Blue-Green Chameleon
1987 GMC Jimmy, TBI350/TH350, 10b, 6" lift, 35" tires.
Neither quite stock.
http://community.webshots.com/user/OutlawLS1
Originally Posted by Pulski
Cvl... this may never happen again, so take note of it. Thank you.
CvlEngAltima is offline
post #4 of 11 Old 06-03-2007, 09:52 PM Thread Starter
cfelicio's Avatar
So I just drain again using the correct plug, and then put like this:
Bolt --> Spring --> Ball --> Transmission
Is that simple? Will I risk dropping the ball or spring inside the transmission?
cfelicio is offline
post #5 of 11 Old 06-03-2007, 11:37 PM Thread Starter
cfelicio's Avatar
Ok, I did put it back on this order, seems to be working fine. I'll do the highway test now
cfelicio is offline
post #6 of 11 Old 06-03-2007, 11:53 PM
You'd lose.
I'm honestly not sure where the bearing and spring would come from.
post #7 of 11 Old 06-04-2007, 12:54 AM
Erect Member
Asleep's Avatar
Quoted: 10 Post(s)
iTrader: 6 reviews
like you said earlier Cvl, its a check valve of some sort. not sure what its for either though.
why the straight 90?
you know its going to be harder to shift when the engine is cold now, right?
Asleep is offline
post #8 of 11 Old 06-04-2007, 01:44 AM Thread Starter
cfelicio's Avatar
I checked on the serv manual, this plug is used for the check of 3rd and 4th gears. I really noticed that 3rd and 4rth felt kinda loose without the ball and spring. Now I put it back, and it's feeling the same way as before.
Asleep, what you recommend? 1/2 of MTL and 1/2 of MT-90 for smoother shifts?
Thanks,
Carlos
PS: And the bolt on the 2nd picture is the correct one (to drain), right?
cfelicio is offline
post #9 of 11 Old 06-04-2007, 03:35 AM
RLR is here
Red Lion's Avatar
Quoted: 5 Post(s)
green circle is the drain plug. it looks like it's a transmission bolt attached but it's not.
Red Lion is offline
post #10 of 11 Old 06-04-2007, 04:33 AM Thread Starter
cfelicio's Avatar
cool, thanks
cfelicio is offline
post #11 of 11 Old 06-04-2007, 07:47 PM
Import Tech.
SHAWN's Avatar
Yep , Yep ... You will need to get the ball and spring back in !!! or you will have shifting issues !! Ball first , then spring , then plug !!
SHAWN
Auto Shop Northwest O.C. OR
'09 Sentra FE+ Driver
'14 Crosstrek Wifes
'98 Sentra SE Time Attack
'09 Titan CC LB SE
'93 Altima SE 5 spd. 13.97 @ 97 MPH ..All Motor ..
( Sold )
( Sold )
My Nissan Site !!
SHAWN is offline
