97 altima Idle and hesitation problem solved! - Nissan Forums : Nissan Forum
post #1 of 2 Old 08-06-2007, 11:48 PM Thread Starter
Here is the story;
I bought 1 97 altima with 290000km 2 month ago.
-Idle was sometime bad, dropping to almost 200 rpm and even killing the engine sometime.
-When driving at slow speed, let's say in first or second gear, the car sometime hesitate. It hapen between 1200 and 2500rpm but only when a was going slow( I mean not full throttle) if a push a little bit more it stop.
- After a few weeks, I realise that if I hit the gaz slowly (when the car is stop) and bring it to about 1100 rpm it always hesitate.
So since the car was not so well maintenance, I did a Full tune-up.
(spark plugs, ignition wires, distributor cap, rotor, injector cleaner.)
Problem still there.
The car had a "ricing" air filtre witch I remove and the problem was still there.
After reading many tips in this forum , I even try a MAP that I had in stock but still the same.
I've scan the ecu and the only "pending or history" code that was on was :
Knock sensor.
After all those Tune up the check engine light finally lid up. (I was happy cause It could help to diagnostic)
The code was TPS .
I had already roughtly clean the throttle body (he was realllllllly dirty) , the car ran a little bit better for 2 days but that it.
So since the TPS code was on , I decide to remove the entire throttle body to clean it.
That was the problem!! I only had to remove it from the intake and clean it with intake-carburator cleaner and the car run great since then (2-weeks about 700km)
So here a advice to everyone who has idle-hesitation problem , first check the throttle body , it's very simple, just remove the air duct and take a look !
Hope I could help someone!
Gabriel
(I did not want to write about it before since I'm a mecanic and I HAD to find the prolem first!)
ghendrix is offline
post #2 of 2 Old 08-07-2007, 12:08 AM
I also had this problem. I cleaned throttle body without any additional trouble shooting or tune up.
but shit. 290000. hows your compression. just curious. and I think everyone is very curious how are your rings now. I have 190K compression is between 165-170psi.
a lot of dirt in throttle body make the throttle plate get stuck or hard to move.
paradox96 is offline
