how do you tighten alternator belt? - Nissan Forums : Nissan Forum
post #1 of 3 Old 09-13-2007, 04:04 AM Thread Starter
i think i know how to tighten the AC belt. adjust the ac pulley down below
how do you adjust the alternator belt?
and how tight do you adjust it?
illmaticnyc is offline
post #2 of 3 Old 09-13-2007, 09:14 AM
See ya
iTrader: 3 reviews
there is a bolt to the left of the alternator.....tighten or loosen to adjust belt tension.
You want it tight, but not so tight that it will break. If it is loose, it won't do any good spinning either. Find a happy medium. I always did a check by squeezing it by hand.
Sassan is offline
post #3 of 3 Old 09-13-2007, 05:50 PM
There is a bolt on the left and right of the alternator on the bottom. Loosen them then loosen the bolt that the tightening bolt is held onto the guide. Then the start tightening the bolt at the top facing perpendicular to all the rest. Tighten all other bolts then you are done.
jeewiz13 is offline
