Old 03-04-2008, 06:41 AM
f91's Avatar
f91 f91 is offline
KA24de Intake manifold shortcut
Long story short, I had the rough idle, loss of power that pops up because the intake manifold gasket fails. Here's a shortcut I found from another forum and it does seem like an easier way to do this job-
I had an earlier comment about my 1999 Nissan Altima Gxe.
It developed an intake manifold leak at #4 cylinder and the
repair manual said because it was very difficult to get at
the manifold bolts it was best to remove the engine head and
then to remove the intake manifold and gasket. Then re-install the head. __Forget this advise__! It requires the removal of too many pieces. The better and easier way (as I learned from a mechanic at Nissan after I had already stripped away many parts) is to remove the starter and then loosen the manifold bolts until there is about a 3/8th inch gap between the manifold and the head. Now remove the top bolts. This is difficult, but can be done. Then remove the old gasket using a thin putty knife. The new gasket can be installed by enclosing it in thin cardboard and sliding it into the 3/8th inch gap from the top of the engine. Before doing this cut out pieces from the gasket that contains the round holes where the manifold bolts are which will then allow the gasket to be slid into place. Then the cardboard must be removed by pulling it out from the bottom with a needle nose plier. Then the bolts must be replaced and torqued in the proper sequence. This procedure is not easy. It may take one day of trial and error, but compared to removing the head it is a snap.
Good luck. Ron at: ra7434@merr.com.
Old 03-04-2008, 06:47 PM
vehemence's Avatar
dthmtlsk8r
Leave it to a Nissan mechanic to find short cuts and let dealerships rip people off for labor!
94 Altima GLE/AT,Greddy SP1 Cat Back,Hi Flow Cat,
OBX 4-2-1 Header,OBX TB Spacer w/bypass,
Bomz Short Ram Intake w/JWT Filter,UR Pulley,
Eprom ECU Chip,JWT Cams,SWA Ground Wires,
NGK Wires/Plugs,FTSB/RSWB, Liquid Ink A-Arm Brace,
Racingline F/R Endlinks,Racingline MMI,
Sprint 2' Drop Springs,Sprint Struts
Slotted/Drilled Rotors,Ceramic Pads,
Enki 17' Polished Rims,Hancook Tires,
Upper/Lower Billet Grill,Depo Clear Bumper/Headlights
Euro Clear Corner Lenses,95-97 Stock No Amber Tails
Old 03-04-2008, 07:38 PM
f91's Avatar
f91 f91 is offline
I got a quote of 500$ from my Nissan dealer. This job, regardless of shortcuts, is not for an average mechanic. Trust me!
Old 03-04-2008, 08:47 PM
vehemence's Avatar
dthmtlsk8r
Well thanks for the how to guide on somthing you claim is to hard for the average mechanic
Old 03-04-2008, 09:00 PM
f91's Avatar
f91 f91 is offline
What I mean to say, is that without help and tips from other folks, the job is "too" tough. Tell ya what, have at it and let me know how it goes.
Old 03-04-2008, 09:12 PM
vehemence's Avatar
dthmtlsk8r
lol maybe when I need to change my manifold gasket
Old 03-04-2008, 09:24 PM
f91's Avatar
f91 f91 is offline
I hope you never have to!
Old 03-04-2008, 09:53 PM
Mr.Nissan KA24DE's Avatar
There are some threads here about that.
93' Altima KA24DE!
Fix it now! When it is right, not when it is very $$$ to fix!!!
Revenge feels so good!
Old 03-04-2008, 10:29 PM
f91's Avatar
f91 f91 is offline
Yes, but the threads I read here involved pulling the intake and lower collector completely off. This seemed like a heck of a time saver.
I actually printed out 1 of threads from here as a guide to help my project. This other way seems much easier.
Old 03-04-2008, 10:39 PM
Here are some threads,
http://www.nissanclub.com/forums/gen...e-removal.html
http://www.nissanclub.com/forums/gen...placement.html
http://www.nissanclub.com/forums/eng...placement.html
Auto Repair Forums -> 93' Nissan Altima
POST 10 AND 13
Old 03-04-2008, 11:01 PM
f91's Avatar
f91 f91 is offline
OK, I'll go slow.
I printed out Paradox's thread and also read jserranos threads about the manifold removal. If YOU would read the first thread in this post, you will see that the proposed method is far less involved than all of the others, including yours. Your pictures were nice and the writeup was good.
The last thread you posted isn't even on this forum, so I'm not sure where you are going? Do you want me to NOT post a different way of doing this? I'm just trying to help.
BTW- The 99 KA24de in an Altima has a lot more crap on it than yours does.
Old 03-04-2008, 11:04 PM
The way you said, should ok, but I dont like to do half-jobs, do it right the first time!!!
By the way I am planning to buy another altima. I hope the intake gasket is bad.
I just love taking stuff part.
lol
Old 03-04-2008, 11:12 PM
f91's Avatar
f91 f91 is offline
You could always look around till you find one with a bad gasket!
Old 03-05-2008, 02:54 AM
OK, I'll go slow.
Read posts 10-17
