interesting reason for fluctuating engine temperature gauge. - Nissan Forums : Nissan Forum
post #1 of 6 Old 06-10-2008, 02:45 AM Thread Starter
so my engine temperature gauge was jumping like someone in heat and I even got check engine codes. I thought it's coolant temp sensor connection.
I did not touch the coolant temp sensor connection.
I replaced the drive belts and the problem was solved. I guess water pump was not spinning consistently or something.
paradox96 is offline
post #2 of 6 Old 06-10-2008, 04:29 AM
Premium Member
BiGJoHn619's Avatar
Quoted: 6 Post(s)
thats wierd.. the belt shoulda still been spinning it.. you sure your gauge isnt tripping? at one point mine used to go to normal and back to cold when im driving.. i noticed my wire wasnt getting a good connection with the sensor...
KA24DE-T
"The T stands for turbo, which translates to "im boosted bitches"
1991 - 240sx KA24DE-T 308whp 296wtq @ 12lbs
2000 - Altima KA24DE-T 372whp 338wtq @ 16lbs on e85
2001 - Altima STOCK Daily
BiGJoHn619 is offline
post #3 of 6 Old 06-11-2008, 11:31 PM
My temp gauge fluctuation was caused by a leak in my radiator. The pressure fluctuation probably did it. I guess that makes 3 reasons for that to happen.
2000 Altima SE
sstupid is offline
post #4 of 6 Old 06-12-2008, 01:45 AM
Datsun Driver
OR you were getting air pockets in the system,
steve68 is offline
post #5 of 6 Old 06-16-2008, 02:01 PM
werd
2000 Altima SE
sstupid is offline
post #6 of 6 Old 06-18-2008, 02:26 AM
I make it happen!
pimp2perfection's Avatar
It never fails lol. When I have a problem someone on here has it to. My girls 2001 alty was doing the same thing. She said the temp gauge was going from cold to hot for like 15 minutes. Like it was floating. I drove the car and nothing (of course). No leaks coming from the radiator or hoses and everything looks legit. She has however noticed a drop in MPG. That I'm still trying to figure out. Leaning toward the O2 sensor there. Sorry for getting off topic.
CAROLINADRAGGIN.COM
I sold the Alty and bought this.
pimp2perfection is offline
