Car shakes when Braking - Nissan Forums : Nissan Forum
post #1 of 8 Old 07-18-2008, 08:26 PM Thread Starter
Whenever I press the brakes, it feels as if the whole car is shaking. I can actually feel my foot shaking when I press the brake pedal when coming down the highway. Any thoughts to why this occurs?
subster is offline
post #2 of 8 Old 07-18-2008, 10:01 PM
The Don.
Quoted: 5 Post(s)
You probably have one or more brake caliper sliding pins that got frozen locked by rust and that rounded out (warped??) the rotors. I would just replace all the rotors, they're cheap. You might also have to replace some calipers and brakes if they don't look right.
'94 Nissan Altima SE, 5spd.
ITEMS FOR SALE
jserrano is offline
post #3 of 8 Old 07-18-2008, 11:33 PM
ya like he said. Car shakes when Braking is normally caused by the roters. They are really cheap. but also like he said, while you're there/down there if your brakes need to be changed, it might be easy to just change them now. however, throughout my entire set of cars I've only had one caliper that messed up where I had to replace it. I guess I'm lucky
First BS in Computer Science, second as an Electronic Engineer.
2001 Altima GXE
OBX 4-2-1
2001 F350 - I like big trucks. :-D
runcoolisback is offline
post #4 of 8 Old 07-19-2008, 03:46 PM
i had the same thing happen and it was a frozen caliper pin. i managed to get the pin loose and then replaced the brake pads since they were all messed up from the pin getting stuck. i didnt bother replacing the rotors because they didnt look warped, and it has worked 100 times better ever since
1997.5 Altima GXE Ltd.
My first car, owned for 9 years and sold 09/2012
My FOR SALE thread
http://www.nissanclub.com/forums/par...rbo-parts.html
zadeluca is offline
post #5 of 8 Old 07-19-2008, 06:23 PM
Sometimes it's possible to tell by looking at it if the rotors are messed up and sometimes it isn't possible. Ask any shop and they will tell you that you can't tell from looking at it. **or they just want to steal our money. lol**
But like I said before, it isn't going to hurt to change them out anyway. the cost of them are REALLY cheap. don't even try turning them unless you just don't have the money. Also check the alienment. are your front tires wearing at the same speed?**the entire surface area.
2001 Altima GXE
OBX 4-2-1
post #6 of 8 Old 07-19-2008, 07:12 PM
^ well yea. if they are only slightly warped you might not be able to tell, but in that case it isnt as important to change them. if they are so heavily warped that you can see it, the is a bigger need to replace them.
My FOR SALE thread
zadeluca is offline
post #7 of 8 Old 07-29-2008, 06:07 AM
my 98 altima drove like crap til i replaced the brakes cleaned the caliper pins and changed the rotors. I found out one of the pins was dirty causing one of my brakes to grab and that caused my rotors to be majorly warped which made the ride worse. I fixed all of them and now it drives great
shorty9191 is offline
post #8 of 8 Old 07-29-2008, 07:33 PM
Brakes 101:
Anytime you replace the brakes, you MUST clean the pins, slides, guides, etc, and then re-lube them. Anytime you replace, or turn the rotors, you MUST replace brake pads. You also have to check brake hardware for leaks, loose caliper, bent caliper, etc.
For better maintenance, you can apply a thin coat of anti-seize lubricant to the back of the rotors, so they don't stick to the hub. You can also apply it to all the bolts and nuts to prevent oxidation.
One more thing... turning rotors = $10-15 each, new rotors = $20-30 each. I also painted the non-contact surfaces of my rotors to prevent them from rusting so fast.
Good Luck!
ukrainetz is offline
