Go Back   Nissanclub.com Nissan Enthusiast Forums > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 1993-2001 Nissan Altima Forums > General Nissan Altima Discussion (1993-2001)
Google Links
» Search Used Cars
Search for used vehicles by ZIP, please enter Zipcode below:
» Log in
Not a member yet?
Register Now!
Sponsors
Sponsors
  #16 (permalink)
Old 07-21-2008, 08:16 PM
lloydbme's Avatar
Altima 2000 Owner
Originally Posted by vehemence View Post
Honestly I never investigated the issue cause I hardly run A/C due2the power and gas it uses up. My chirp went away on its own but,when I feel the A/C run thru a cycle or say the fans kick on while im at a consistant speed, that is when I feel a slight hesitation in power. It could just be a load issue that the belt is taking on so check that first.
I see. The way I understand it when the A/C kicks in its expected that there will be slight power loss simply because theres a bigger load on the engine and it needs to readjust.
I'm looking to get this fixed before my girlfriend and I go on our trip to Quebec City in a month. Having A/C is definitely a must on such a long trip on the highway so I want to be able to use it without being afraid the car will blow up. haha.
  #17 (permalink)
Old 07-21-2008, 08:51 PM
Datsun Driver
Just turn the steering to right full lock(all the way) the adjuster pully is right there, don't even have to jack up the car! and yes A/C is the best, in town and trips!
  #18 (permalink)
Old 07-21-2008, 09:12 PM
lloydbme's Avatar
Altima 2000 Owner
Oh yea? That sounds easy enough. I'll have a look when I get off from work. Is there anything I should look out for or do I follow the same instructions as you previously posted ?
Underneath the car, remove the splash guard 2 10mm bolts, and the adjuster is right there 14mm wrench loosen the nut on the adjustment pully, turn the bolt counter clock wise to tighten the belt.
For instance, is there a splash guard that I need to remove? And what do you mean by loosening the nut before turning the bolt? Counter-clockwise to tighten (not righty-tighty eh...)?
Haha sorry for the questions I'm a newbie and like to know as many details as possible so I can be ready when I actually do it. Most likely I'm making too much out of a simple task though so thanks in advance for your patience.
  #19 (permalink)
Old 07-22-2008, 03:38 AM
Datsun Driver
Print the instructions and go lay next to the car, everything will come together,
  #20 (permalink)
Old 07-23-2008, 08:59 PM
I have a 00 Altima SE and had exactly the same problem. It was solved when I changed my old cracked surpentine belt (not the AC belt).
Originally Posted by lloydbme View Post
Hello,
I have a 2000 Altima GXE. I recently have taken it in for maintenance and such. All the fluid levels, etc are fine.
My question is this: When on the highway at over maybe 2300rpm, if the A/C is on, the car will at random intervals make a short squeak/screech noise. This is always accompanied by a slightly noticeable loss of power. It usually lasts for less than 1 second. Everything works fine, and the A/C is still cold as ever for the whole trip. I've driven the car for around 3 hours straight on the highway and there are no issues apart from this slight squeak.
From what I've read by using the search function, it seems like the problem is with slack on the alternator belt and that tightening it will be the solution.
If anyone has any ideas or opinions please let me know
  #21 (permalink)
Old 07-23-2008, 09:44 PM
lloydbme's Avatar
Altima 2000 Owner
I hope its not that
I'm just going to post a link to a thread I found on here that dealt with changing belts because the pictures are extremely helpful. Its for my own reference.
http://www.nissanclub.com/forums/gen...y-install.html
  #22 (permalink)
Old 07-24-2008, 09:12 PM
Anyway, the good news is that the problem is not with the AC. Originally the belt was changed on my car not to get rid of the screech. The belt was just too old and cracked and needed to be replaced. The changing accidentally solved the AC screeching problem. So if your belt happens to be old, just change it. If not, just adjust it and the screech will go. Good luck.
I hope its not that
  #23 (permalink)
Old 07-28-2008, 10:04 PM
lloydbme's Avatar
Altima 2000 Owner
Hello again,
So I tried to tighten both the A/C belt and the Alternator belt. I think I ran into a few problems:
1. The bolt that I need to loosen before tightening the tensioning bolt seems to be immovable on both the Alternator belt and the A/C belt
2. Even despite #1, I was able to tighten (turn to the right because righty tighty) the two belts. The Alternator belt I think I found a good balance for. Its tighter than before but not the absolute tightest that I can get it to go.
3. The A/C tightening bolt...seems to be able to turn forever. When I turn the bolt, I can tell that I am tightening it, but it doesnt have the same kind of "tight" feeling as when I tighten the alternator belt. It feels the same after a few turns as it did before...I'm wondering if its because I haven't loosened the pulley, or if I should keep going until I get that "I can't tighten it anymore" feeling and back off a little bit?
I haven't actually gone and tried out the car yet though because I know its traffic hour out there right now, but I will try it later on tonight. However, that means if I haven't fixed the problem I will have to work on it tmw afternoon :P
Thanks in advance.
  #24 (permalink)
Old 08-21-2008, 11:56 AM
lloydbme's Avatar
Altima 2000 Owner
I just wanted to mention that I got the belts (both) replaced at the dealership and the problem is now fixed
  #25 (permalink)
Old 08-21-2008, 04:03 PM
How much did it cost you? I'm getting lazy
97 Altima GXE
Aiwa CDC-MP3 (Need to upgrade desperately)
Kicker DS60 & DS680 Speakers
Wants:
Aftermarket Intake
Tons of dents removed
Paint Job
  #26 (permalink)
Old 08-21-2008, 04:04 PM
lloydbme's Avatar
Altima 2000 Owner
I believe it was $80CAD for the two belts with labour included.
Powered by vBadvanced CMPS v3.0 RC1
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
AutoForums.com is the premier network of enthusiast-owned enthusiast-operated automotive communities.
We operate more than 100 automotive forums where our users consult peers for shopping information and advice, and share experiences and opinions as a community.
Visit AutoForums.com today.
For advertising information, please visit our AutoForums.com website and Contact Us, or send an email message to sales@autoforums.com.
