Go Back   Nissanclub.com Nissan Enthusiast Forums > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 1993-2001 Nissan Altima Forums > General Nissan Altima Discussion (1993-2001)
Google Links
» Log in
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 07-20-2008, 03:05 PM
lloydbme's Avatar
lloydbme lloydbme is offline
Altima 2000 Owner
A/C Screech
Hello,
I have a 2000 Altima GXE. I recently have taken it in for maintenance and such. All the fluid levels, etc are fine.
My question is this: When on the highway at over maybe 2300rpm, if the A/C is on, the car will at random intervals make a short squeak/screech noise. This is always accompanied by a slightly noticeable loss of power. It usually lasts for less than 1 second. Everything works fine, and the A/C is still cold as ever for the whole trip. I've driven the car for around 3 hours straight on the highway and there are no issues apart from this slight squeak.
From what I've read by using the search function, it seems like the problem is with slack on the alternator belt and that tightening it will be the solution.
If anyone has any ideas or opinions please let me know
Old 07-20-2008, 03:36 PM
rick66's Avatar
rick66 rick66 is offline
Pepsi Man
My father inlaw was having the same problem with his 94 Nissan. A friend of mine who is a long time(22yr) Nissan mechanic told him to tighten up the belt. He did and problem was solved.
05 3.5 SE Satin White
Nismo CAI, Rays Eng. Nismo 18x8.5 w/BFG 245/45Z/18, Custom Magnaflow Exhaust, SER Tails & R. Bumper, SER Springs/Struts/Shocks,
Stillen RSB, Stillen Front Lip, Active Tuning S5 Grille, 20% Tint, Nismo Mats and M3 Rear Window Spoiler
Gallery Pics- http://s212.photobucket.com/albums/c...t=f80bb212.pbw
Old 07-20-2008, 04:18 PM
kishan kishan is offline
i have a 96 altima, sometimes when i rev go high rpm's the screech stays for about 2 or 3 seconds, i got it checked and the guy said it might be the compressor, he wasnt much of a professional though, he worked at lesSchwab's tires
Old 07-20-2008, 10:25 PM
AkotaHsky AkotaHsky is offline
I got that issue in my 01. I bet its prob just the belt. I been to lazy to check since I hardly use the AC less its raining or seriously hot as hell. An I live in FL =\
Old 07-20-2008, 11:27 PM
j0ng101 j0ng101 is offline
I just had my belts changed and actually get that screeching sound all the time now, it happens for the first few seconds when i start(with a/c on) and usually at times when the torque is a little higher. I had it looked at by a friend who is a mechanic, and he said its the a/c compressor. Just a word of advice, new a/c compressors run around 335, you can get used ones, just be careful b/c the can have gunk in them and blow it into your a/c system
audio setup:
step1:infiniti kappa door speakers
step2:JBL Amp 400w mono
step3: 10" infiniti Kappa Perfect short trunked
step4: kenwood mosfet head unit with ipod hook up + sirius
current work
Filling, molding, and repainting sideskirts, sanding and fixing shaved rear doors, tints.
Old 07-21-2008, 02:48 AM
steve68 steve68 is offline
Datsun Driver
Tighten the A/C belt, I put on a Nissan belt last month and I've tighten/ adjusted it twice!
Old 07-21-2008, 09:39 AM
lloydbme's Avatar
Altima 2000 Owner
How does one tighten the A/C belt? I've managed to tighten the alternator belt and it seemed to make it a little better but the chirp is still there.
Old 07-21-2008, 12:31 PM
rick66's Avatar
Pepsi Man
Seems like theres 1 adjustment you do from the top side and 1 from the bottom side? Sorry I cant be more specific...
Old 07-21-2008, 12:32 PM
Datsun Driver
Underneath the car, remove the splash guard 2 10mm bolts, and the adjuster is right there 14mm wrench loosen the nut on the adjustment pully, turn the bolt counter clock wise to tighten the belt.
When your doing this its probably a good time to check the belt,
Old 07-21-2008, 02:23 PM
jserrano jserrano is offline
The Don.
AC screech and chirps are mainly due to a loose AC belt, ie. the AC pulley needs adjustment, like steve68 said.
'94 Nissan Altima SE 2.4L, 5spd. Ultra Red (AJ4).
Erebuni 905, HotShot Header & CAI, UR Pulley, Calum ECU,
HUD & ATC retrofitted, DEPO lamps w Silverstars, NGK Ignition wires.
Old 07-21-2008, 03:03 PM
lloydbme's Avatar
Altima 2000 Owner
I see I see. Thanks for the advice guys. Since I don't have a lift, it probably means I should take it in to the dealership then to get it done. It doesn't seem like its too complicated so hopefully it won't be expensive.
Old 07-21-2008, 04:45 PM
vehemence's Avatar
vehemence vehemence is offline
dthmtlsk8r
mine has done that in the past but only when the A/C comp. or fans would turn on and run thru its cycle. Just a small chirp and slight hesitation in power. could be a belt or you comp. going bad. If its not the belt I would just live with it.
94 Altima GLE/AT,Greddy SP1 Cat Back,Hi Flow Cat,
OBX 4-2-1 Header,OBX TB Spacer w/bypass,
Bomz Short Ram Intake w/JWT Filter,UR Pulley,
Eprom ECU Chip,JWT Cams,SWA Ground Wires,
NGK Wires/Plugs,FTSB/RSWB, Liquid Ink A-Arm Brace,
Racingline F/R Endlinks,Racingline MMI,
Sprint 2' Drop Springs,Sprint Struts
Slotted/Drilled Rotors,Ceramic Pads,
Enki 17' Polished Rims,Hancook Tires,
Upper/Lower Billet Grill,Depo Clear Bumper/Headlights
Euro Clear Corner Lenses,95-97 Stock No Amber Tails
Old 07-21-2008, 05:13 PM
lloydbme's Avatar
Altima 2000 Owner
What was the problem for you if you ever found out? Bad belt or comp ?
Old 07-21-2008, 05:23 PM
Actually, mine is more or less a whinning you hear when your inside the car.
Old 07-21-2008, 08:01 PM
vehemence's Avatar
dthmtlsk8r
Honestly I never investigated the issue cause I hardly run A/C due2the power and gas it uses up. My chirp went away on its own but,when I feel the A/C run thru a cycle or say the fans kick on while im at a consistant speed, that is when I feel a slight hesitation in power. It could just be a load issue that the belt is taking on so check that first.
Powered by vBadvanced CMPS v3.0 RC1
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
AutoForums.com is the premier network of enthusiast-owned enthusiast-operated automotive communities.
We operate more than 100 automotive forums where our users consult peers for shopping information and advice, and share experiences and opinions as a community.
Visit AutoForums.com today.
For advertising information, please visit our AutoForums.com website and Contact Us, or send an email message to sales@autoforums.com.
