Go Back   Nissanclub.com Nissan Enthusiast Forums > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 1993-2001 Nissan Altima Forums > General Nissan Altima Discussion (1993-2001)
Google Links
» Search Used Cars
Search for used vehicles by ZIP, please enter Zipcode below:
» Log in
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 07-25-2008, 05:48 AM
Grade-A Cherry since 2004
Head Gasket inquiry...
Hey all!
This has probably been asked before, so sorry for the retread. I couldn't find anything on it. Anyway, I'm getting ready to do a head gasket on my 99 SE and I'm pretty sure that it has Torque To Yield head bolts on it. However, every place I've seen has that sells head bolts have ones that only go up to 98 for the Altima. The shop manual doesn't say anything about replacing the head bolts, either. So my question is does anyone know if you have to replace the head bolts on this engine when doing a head gasket repair? And if so, where can I find aftermarket head bolts for the newer engine? I would think the bolts for up to 98 would be the same, but who knows. Any help would be greatly appreciated!
Old 07-25-2008, 07:05 AM
Hmmm, sorry but IMO I'd go with the dealer part... I'd say its too risky to use aftermarket on something like that. But I don't think they need to be replaced.
Here is the diagram
The head bolts are 11056, and it shows that these are on the 98-01 diagrams. Whats more, If you select 93-97 model, it shows identical bolts, so they are the same. However at 4.26 a pop+shipping :ouch:
Good Luck~
Old 07-25-2008, 04:11 PM
98gle#2's Avatar
white on rice
Good Luck~
Well it is generally recommended that you replace the headbolts.
Aftermarket headstuds/bolts are perfectly safe, no need to pay out the anus for dealer parts.
White 1998 Altima GLE
Injen wai
OBX header & cat-back
Some subs and amps
Black '01 headlights
Powerslots & hawks
Spec-V Rims powdercoated black
Tokico struts
Suspension Techniques springs
Originally Posted by Red Lion
I'm glad SOMEBODY finally said it. And of course it'd be YOU
Originally Posted by Eclypse
Considering you dont have a lift and I'm picturing this thing falling on your face, you may want to clearly understand what is involved here.
Old 07-25-2008, 06:56 PM
Datsun Driver
I reused mine, 98 134K.
Old 07-25-2008, 07:40 PM
Steve68,
Did you have any issues with reusing them? How many miles since you did yours? I'm leaning towards reusing mine as the dealership wanted about 4.50 each bolt and it would take a week or so to get here. Planned on doing it this weekend possibly. Thanks to all for the input. I'll see if I can source the parts on hand somewhere in the Twin Cities. If not, I'll probably reuse the old bolts.
Old 07-25-2008, 11:17 PM
Datsun Driver
About 3K miles so far, no problems at all head torqued up just fine, I'd reuse them,
I have a 88 BMW M3, the head bolts are $7.50 my price, over the counter is about $20, and those are one time use,
Old 07-26-2008, 06:37 AM
If you reuse them, make sure you put each one back where they came from. Obviously check all for wear and tear (missing threads, etc...) and replace any that need be. If any give at all during re-tightening (torque drops), stop immediately and back off. That one will need a replacement. Believe me, drilling bolts out of the head is not a good way to spend a weekend!
Leaks will usually develop not from bad bolts, but incorrect re-tightening. Make sure you torque them very evenly, and gradually.
Best of luck!~
Old 07-27-2008, 02:30 AM
chuck34gboro's Avatar
if you don't have over 100k miles and the engine didn't overheat, you'll probably be ok. just make sure you get someone to trace tap the holes to clean them out. if you can't find anybody with the right tap, you can spray some carb cleaner in the holes and let it sit for a few minutes, blow it out with compressed air. then lube up the original bolts with lucas and run them all the way back in slowly them repeat the process.
if you got over 100k on the motor or the head warped from overheating, the bolts are probably stretched and should be replaced. it this case, you should probably take it to a machine shop to have them trace the threads.
Old 07-27-2008, 04:58 PM
Well, good news! I found a dealer in the Cities that had 30 on hand that was NOS for 3.82 a piece. I ended up getting the 10 bolts just so I wouldn't have to worry about it. Thanks to all for the replies! It looks like I'll have to do it next weekend, though... :-(
Old 07-27-2008, 05:40 PM
Asleep's Avatar
n00b hating hall mod
u should have been able to measure them as well. there was a measurement for the bolts on my sr and everyone of them was well within the limits.
Originally Posted by rEvVoMaNiAc
You forget that asleep insists on writing with perfect grammar, perfect spelling, and irregular punctuation (no apostrophes). It's his trademark.
Originally Posted by chinabean
you didn't know chuck norris got a poster of asleep up on his wall...
Originally Posted by Rick View Post
asleep is a stream of off-color and low-cooth jokes in person as well. I've been recycling jokes I heard from him for years. He is known by my friends as "the sick fuck."
Nissan Moderators needed
contact Sassan @ www.SUPERNISSANS.net
http://www.cardomain.com/id/our rides
Powered by vBadvanced CMPS v3.0 RC1
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
AutoForums.com is the premier network of enthusiast-owned enthusiast-operated automotive communities.
We operate more than 100 automotive forums where our users consult peers for shopping information and advice, and share experiences and opinions as a community.
Visit AutoForums.com today.
For advertising information, please visit our AutoForums.com website and Contact Us, or send an email message to sales@autoforums.com.
