  #31 (permalink)
Old 10-05-2008, 09:19 PM
1800bucks's Avatar
Cheap Bastard
My '97 has 223,421 on it. I had a used tranny (5 spd) put in it at 195K, plus the typical wear and tear things. Has a slight hesitation, but other than that, it's probably the best Nissan I've owned, except for the '86 720 which had 228K on it when I sold it, or maybe the 86.5 HB that had 254K on it when I "let it go" for $2500. Oops, can't forget the '95 s/c HB that I sold last year with 225K miles which I still see on the road from time to time.
  #32 (permalink)
Old 10-07-2008, 07:48 AM
HBs were bulletproof. My best friend had over 400K on his before he blew a head gasket and toasted it.
2000 Altima SE
  #33 (permalink)
Old 10-09-2008, 09:47 PM
Liking it
94 Se 5speed
Brought it at 189k
Change all the seals on the engine since it was leaking a lot of oil
Change the clutch since it starting to slip and the starter since they broke it while taking it out
Tune up
201k
Change Clutch slave cylinder since pedal goes to the floor
207k
Change Fuel Pump
210k
Change Alternator
214k still running strong until who knows when
Think it still has original engine and tranny since it was leaking all that oil from the seal which is why the owner sold it.
  #34 (permalink)
Old 10-19-2008, 05:24 AM
jwizs23's Avatar
created with you in mind
267k new starter,new fuel pump, and new alt. and the usually maintence nissan altima 94
  #35 (permalink)
Old 10-20-2008, 12:48 AM
heat's Avatar
178000 km
111000 mi
replaced:
battery
stereo
rotors and pads
cap, rotor, plugs
air fitler
clutch
1998 Nissan Altima & 2001 Honda Prelude
  #36 (permalink)
Old 10-21-2008, 12:08 AM
185k and still going... for now, at least
185k... no engine replacement.
- replaced tie rods twice (once, and now they need it again)
- sway bar stuff needs to be replaced
- drive axle is leaking grease
- fan only works on #4
- service engine light is always on
- driver side window requires a lot of effort to roll up; you have to pull really hard on the button
im hoping i can get some more mileage of this car. ive really enjoyed it thus far and do NOT want to have to go through the hassle of buying a new car again.
  #37 (permalink)
Old 10-21-2008, 01:30 AM
1997GXE's Avatar
97AltimGXE
I just hit 85,500k... Purchased in 2006 with 66k...
No major problems yet.......
Changed in the past 2 years:
radiator, belts, axles,o2 sensor, vc gasket, gas tank/ fuel float, struts/ drive side mounts, motor mounts (4).
Getting a clunk sound when i turn to the right once in a while....
Mod List
Place Racing Intake with k&n filter
SE Sides
Erebuni 905 rear
Falken Ziex ZE-912
98 alty 6 spoke alloy rims
UR Pulley
JDM smoked tail lights
IBI Eyelids
93-94 Grill
* New Pics to come Soon*
  #38 (permalink)
Old 10-21-2008, 03:38 AM
Mr.Nissan KA24DE's Avatar
around 200000
Intake manifold, and valve cover gasket,
Starter
CV joint
STRUT
Ign switch key cyl
Engine mounts
93' Altima KA24DE!
Fix it now! When it is right, not when it is very $$$ to fix!!!
Revenge feels so good!
  #39 (permalink)
Old 10-21-2008, 08:35 AM
I have the exact same issue. wtf?
  #40 (permalink)
Old 10-27-2008, 08:37 PM
82009's Avatar
'96 Altima GXE
278K miles and counting
Original tranny gave up the ghost at 258K
Motor is still original
I've gone through several alternators, of course.
Replaced the a/c compressor at 250K
Only mod isthe Motegi MR7's
Love this car
  #41 (permalink)
Old 10-27-2008, 11:25 PM
porschebk85's Avatar
2nd Gen Boy
The drivers side window control is known to be faulty, we had to replace ours at about 60K about three years ago.
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
2001 Altima GXE - [8K HIDs] [De-badged] [ UR Pulley ] [injen intake] [OEM Spoiler] [OBX TB Spacer] [40% Tint] [ Stillen Rotors & Hawk HPS Pads] [TYC Tails] [ license]
<Car Domain> <♪My Pandora♪> Proud fiancés of an EMT-I/Firefighter
  #42 (permalink)
Old 10-28-2008, 10:54 PM
blackalti's Avatar
the black alti
112xxx, owned for 3 years bought it with 35k
radiator (i drove it for 6 months with a 6" crack on top though without a drop lossed
2 alternators (4 12's will do it)
both cv joints
motor mounts
2 batteries (4 12's will do it)
valve cover gasket
inner tie rods (thats on my to-do list)
you cant see me!!
  #43 (permalink)
Old 11-03-2008, 03:34 AM
1996 GXE all original 1 owner
Over 250k running stong. I did complete tune-up, replaced radiator, waterpump, thermostat, hoses, belts & alternator earlier this year. Now it just started stalling. Sometimes it crank back & sometimes it wont.
  #44 (permalink)
Old 11-03-2008, 12:52 PM
john21031's Avatar
128,xxx on a 95 speed. Replaced valve cover gasket, both cv boots, and maintenance like tune up, hoses, belts, brakes, fluids, etc.
Rear defogger and cruise control dont work. CEL on calling for rear oxygen sensor replacement.
Drives well.
1995 Nissan Altima GXE 5 speed, 152,000 miles. Everything is completely stock. Had no problems with the car. Time to do the struts but kinda hesitating to spend that much money. Would love to do water pump for preventive maint. Other than that, runs like a swiss clock. (Worked as mechanic for a year - experience, priceless).
  #45 (permalink)
Old 11-03-2008, 05:40 PM
Location: montgomery/auburn/tuscaloosa Al via doraville ga
93 manual. approaching 328,000. engine swap around 200k on it if not less. only problem is stalling and rear windows wont go down. Other than that, normal wear and tear in which i stay on top of.
