97 Altima P0400 & P0325 - Nissan Forums : Nissan Forum
post #1 of 5 Old 11-17-2008, 03:48 PM Thread Starter
I recently did an intake manifold gasket repair for a P0304 (cylinder 4 misfire). I put it all back together and now I am getting a P0400 (insufficient egr flow) and a P0325 (Knock Sensor). I tried cleaning the egr because I read in a forum that a knock sensor code usually comes with another code, so they said to focus on the EGR. I removed the egr and applied vacuum it holds. I did the checks on the BPT and it as well holds vacuum. i even checked the solenoid valve and it is also working properly. I am stumped and I need some suggestions from someone who did the job and got the same codes or someone who knows why the codes appeared. Thanks in advance.
Eddiestar is offline
post #2 of 5 Old 11-17-2008, 06:30 PM
The Don.
Quoted: 5 Post(s)
You need to get the engine warmed up and then sense the diaphragm from underneath the EGR valve. Next softly raised and lower the engine around the 2000 rpm point. If you get very little to no movement then you've confirmed an EGR problem. I've written extensively on this stuff so do a search and hopefully that will help. If not, then just post back.
For the KS, you'll likely have to replace it.
'94 Nissan Altima SE, 5spd.
ITEMS FOR SALE
jserrano is offline
post #3 of 5 Old 11-21-2008, 05:35 PM Thread Starter
Fixed P0400 and P0325 codes I Hope
I had the two vacuum lines backwards so the EGR wasn't getting movement under load of the motor. I had the green which is "C" I believe swapped with the gray which is "B" I believe. The "C" is supposed to have vacuum under load of the motor and didn't. Instead "B" had the load. I read in your forum and I found it. Thanks for all the help JSERRANO you are the best.
post #4 of 5 Old 11-21-2008, 07:44 PM
The Don.
Quoted: 5 Post(s)
Nice to hear you fixed it. And thanks for coming back to explain what was wrong. Cheers.
ITEMS FOR SALE
jserrano is offline
post #5 of 5 Old 11-21-2008, 08:15 PM
Sleeper
DexGTR's Avatar
i need to the intake manifold gasket replacement...and this is a good thing to watch out for...i'll prolly get some tape and label each ends so that i'll know which part comes together when it's time to put it all back together.
93 Altima SE (photchopped)
DexGTR is offline
