Go Back   Nissan Forums: Nissan Altima Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 1993-2001 Nissan Altima Forums > General Nissan Altima Discussion (1993-2001)
Old 11-21-2008, 04:22 AM
01NismoAltima's Avatar
Sentra/Altima part swap??
If anyone has ever cared to notice, the speedometer clusters in a 00-01 Altima Look Exactly the same as the ones used in 02-03 Sentra SE-R,
I cant get the pictur to come up, but most of you know what im talking about. If not Google it.
My question is, will it fit? (I dont mean in the dash), is the wire harness the same, and if new or used can the od be rest to display the new car accuall miles????
Ive searched high and low and cant find this answer. I even went to the dealership, had the diagrams pulled up, and printed, but none of there "Techs" could give me a striate answer.
After looking at them myself, I think it will. but again, I dont really know.
Old 11-21-2008, 05:38 AM
allblackedout111's Avatar
You can't see inside
I doubt it.
I can't give you a solid answer though. If they look so similar, why are you trying to swap them?
AngryBot: Well when two admins fall deeply in love...they can't physically have children so they adopt one and that's how a moderator is made.
Pulski: Just because you have a less slow car than some here, doesn't make you any less of an idiot.
Old 11-21-2008, 12:16 PM
The Don.
No, it won't work. With many of the the newer car designs, car manufacturers are taking advantage of a different design called, Controller Area Network (CAN). If you know how a computer Local Area Network (LAN) operates then you have the basis for how the CAN works.
The older speedometers in Nissans are electronic based while the newer Nissans are CAN based. What's the difference? Well instead of communicating via electrical signaling between control units, they communicate with each other through only two wires, and each control unit has its own CAN transceiver.
In summary, the Sentra has CAN connected to the ECU, ATCU, and combination meter (instrument cluster). While the older Altimas does not. The 2002 and newer Altimas even has a lot more systems integrated into CAN. So the disparity becomes wider.
ITEMS FOR SALE
Old 11-21-2008, 03:15 PM
DIY'er
^^ *CLAP CLAP CLAP CLAP*
ENCORE ENCORE! lol
http://www.nissanclub.com/forums/signaturepics/sigpic20104_1.gif
Camber Bolts are for Pussies
1 set of 1st/2nd gen drop zone coilovers
never installed
100 shipped
1 set of 1st/2nd gen indigo gauges
10 + shipping
Old 11-21-2008, 08:43 PM
Originally Posted by drunkmunky View Post
ENCORE ENCORE! lol
It actually would be hilarious if he came back with some random ass technical information.
Old 11-22-2008, 01:21 AM
BeeCee's Avatar
You Already Know
ENCORE ENCORE! lol
Co-sign that one. Jserrano on the come thru again. Even without that info though, I would doubt the harnesses would even match up. But w/e, its not gonna work anyway.
The Alt.™
1999 Nissan Altima GXE
The Garage:
http://www.nissanclub.com/forums/vbp...do=view&g=1534
UPDATE! 4/29/09 Check It Out!
http://www.nissanclub.com/forums/nis...77-rims-4.html
Old 11-22-2008, 06:31 AM
thanks for the input!! its to bad really, I thought it would look unique inside of an altima.
