weird gas smell - Nissan Forums : Nissan Forum
post #1 of 14 Old 03-13-2002, 10:21 AM Thread Starter
weird gas smell
when im just riding around or just start up my car there is usually a smell of gas or someother weird smell thats in my car is that a problem?? an if it is whats it coming from
Altima Zero1994 is offline
post #2 of 14 Old 03-13-2002, 10:42 AM
Peterson's Avatar
Quoted: 1 Post(s)
If it sorta smells like rotten eggs than it's your catalytic convertor going.
Peterson is offline
post #3 of 14 Old 03-13-2002, 01:19 PM
sittin on chrome....
bzkit's Avatar
I don't have a catalytic converter, but mine doesn't smell all that bad.
The car...
94' Ultra Red SE
bzkit is offline
post #4 of 14 Old 03-13-2002, 06:24 PM
Peterson's Avatar
Quoted: 1 Post(s)
If you don't have a cat then yours wouldn't smell at all.....
The rotten smell is the catalyst agents in the convertor going bad.
Peterson is offline
post #5 of 14 Old 03-13-2002, 06:35 PM
from way way back
if you dont have a cat than your not passing inspection either...
CJB_316 is offline
post #6 of 14 Old 03-13-2002, 06:38 PM
Resident drunken chef!
scootter's Avatar
Did you check under the hood for any gas leaks? My cousin had the same smell(on a protege), so I opened up the hood, and one of his injectors was leaking realy bad
scootter is offline
post #7 of 14 Old 03-13-2002, 07:41 PM
i had the same problem but it was teh Evaporatoin control cannister which is located next to the fuel filter. What it does is takes all the exhause emissions and regenerates them back to the motor to be burned and if part goes out it make your car smell like gas. until its fixed thats what is wrong with your care not your cat. converter.
94 altima se
66 black mustang
pierre45eb is offline
post #8 of 14 Old 03-16-2002, 10:31 PM
bzkit's Avatar
They don't have inspections here in kentucky.. I need a new cat though, anyone know where I can get a really cheap one?
The car...
94' Ultra Red SE
bzkit is offline
post #9 of 14 Old 03-16-2002, 10:34 PM
Peterson's Avatar
Quoted: 1 Post(s)
Peterson is offline
post #10 of 14 Old 03-16-2002, 11:10 PM
Jr. Lord Of Search
catco hi-flow cat from summitracing.com
Mods: Fan Delete///Borla Exhaust
MikeV is offline
post #11 of 14 Old 03-16-2002, 11:26 PM
Damn! I Drive a Civic
are you sure you putting gas in the right place? theres this little lever inside the car push it down and opens a gas cap on the rear drivers side put the gas in there.... it helped me with the smell alot!! j/k
06 Altima 2.5S - 5 Speed
m3dia_lab is offline
post #12 of 14 Old 03-17-2002, 01:51 AM
bzkit's Avatar
www.summitracing.com
thanks
The car...
94' Ultra Red SE
bzkit is offline
post #13 of 14 Old 03-22-2002, 06:31 AM
Sexy Biatch
Are you describing the Exhaust Gas Recirculation (EGR) valve?
Mechanic was telling me that was the cause of the smell for me. Although the smell coming from my car is occasional. Although since yesterday I have noticed a gas smell in the car when I enter after having it parked for a bit.
mc-fine is offline
post #14 of 14 Old 03-23-2002, 12:01 AM
It does sound like a EVAP problem, but the EVAP system has nothing to do with the exhaust. It recycles gasoline evaporation from the gas tank back into the engine intake.
kenshi is offline
