Broken Coil Spring Replace?? or Not - Nissan Forums : Nissan Forum
post #1 of 16 Old 01-17-2009, 05:03 AM Thread Starter
I recently took my car to mechanic for starting problems and they told me I had a broken coil spring. I am pretty sure it broke recently when my car took a 180 turn when I hit a pile of snow when exiting from freeway. Luckily car didnt hit anything and no one was injured.
Now my question is should I replace it or not. The mechanic wants to charge $700 to replace both, install and align. I really dont want to spend that much.
Can I just drive without replacing. Mechanic was telling it might get into way of my tire and burst it. I am not sure how.
ANY Advice??
Can I just find a salavge spring and just get one replaced??
p.s. I have 2001 Altima with Almost 135K
zixy_tris is offline
post #2 of 16 Old 01-17-2009, 06:27 AM
2600 lbs
Quoted: 21 Post(s)
iTrader: 4 reviews
replacing springs is pretty easy with the right tools. I actually have a set of OEM springs in good condition if you want to pick some up on the real cheap.
If your coil is actually broken that is something that needs immediate attention. If a coil is broken though, you should be riding lower on that corner. I would use some jack stands and get the car in the air yourself and take of the wheels and check out the suspension yourself to see exactly how the spring is broken.
If you're going to fix it yourself its really not hard to change struts and springs. The only specialty tool you'll need is a spring compressor but you could probably rent one somewhere for a day. I happen to own an old school style one.
allblackedout111 is online now
post #3 of 16 Old 01-17-2009, 03:55 PM Thread Starter
I would be more than happy to buy from you. I dont think I can do it myself as it is extreme cold out here and I am really busy too. How much should it cost a mechanic to do it. They told me 2hr per side. If I can find some one who can just replace the coil spring on one side for cheap I will probably do that. I would prefer buying from you because if I go aftermarket then I have to replace both sides to match it. With OEM I will just get one side down.
post #4 of 16 Old 01-17-2009, 05:23 PM
zixy_tris are you on the NYC area? If so I could hook u up with installing the springs
Nissan Altima 99 KA-T
Sleeper in the making!
http://www.nissanclub.com/forums/mem...-t-altima.html
Parts for SALE!!!! Click HERE
Ultamaflow is offline
post #5 of 16 Old 01-17-2009, 07:30 PM Thread Starter
Nope I m in Minnesota. Some one around twin cities can you help me??
post #6 of 16 Old 01-17-2009, 08:37 PM
Ну Погоди!!!!
sergey85's Avatar
Quoted: 1 Post(s)
post in the regional section im sure that woould help
2002 Maxima GLE Silver on Black | Berk Intake w/AEM Dryflow | Clear Sidemarker Lights w/PIAA L.E.D |Fibre Customs EyeLids | PIAA White Fogs | 5% Limo Tint | Brembo Blanks and Hawk HPS Pads|CATTMAN RSB|Ebay FSTB|VIAS Block Plate| OEM Spoiler|NWP Engeneering Intake Spacers (not yet installed)| 07 350z rims(needs tires)
>>>>>INFINITIHELP.COM and NISSANHELP.COM FREE MANUALS, TECH HELP AND MORE<<<<<
sergey85 is offline
post #7 of 16 Old 01-18-2009, 04:34 AM Thread Starter
I am able to find a salvage strut assy with spring on ebay. Do you guys think it is better to install these? Also I am confused. I tried to look above the tire and I did see the broken spring. However the spring is compressed still. It seems like it just broke off at the very bottom part it sits on the plate. Will try to post pictures later?
eBay Motors: 2001 Nissan Altima Front Right Strut (item 350121643225 end time Feb-04-09 10:56:20 PST)
Will be much cheaper on labor to install this. these are $50 shipped. I am trying to see if I can get a matching pair from same car
post #8 of 16 Old 01-18-2009, 09:11 PM
2600 lbs
Quoted: 21 Post(s)
iTrader: 4 reviews
it is very easy to just install a strut with a spring already on it. It's only 5 bolts besides the lug nuts.
post #9 of 16 Old 01-18-2009, 10:57 PM
RLR is here
Red Lion's Avatar
Quoted: 5 Post(s)
If you don't want to replace them yourself, go search around for a better price. I was once quoted $200 to do a four-corner spring and strut install (though I had already bought the springs and struts). $700 seems a bit high; it shouldn't take more than an hour with proper tools, minus alignment and cost of a spring.
Red Lion is offline
post #10 of 16 Old 01-19-2009, 01:08 AM
99 altima
pac99altima's Avatar
+1 ..yea it isnt hard at all ...me and my homeboy must of attacked my suspension 5times in 2weeks 2yrs ago
Carbon fiber hood is back!!
R.I.P Custom integra Lip ...Hello STILLEN Front Lip!
pac99altima is offline
post #11 of 16 Old 01-21-2009, 03:11 AM Thread Starter
Thanks for all the help. I bought a matching pair of strut assemblies from ebay for $115 shipped. Came from a car with 62K miles. I got them installed for $70 bucks from a local guy.
I have the struts from my car. Front Right strut assmbly is good if someone looking for only one side I can give it for really cheap.
post #12 of 16 Old 01-22-2009, 02:19 AM
99 altima
strut mounts?
post #13 of 16 Old 01-22-2009, 05:34 AM Thread Starter
Originally Posted by pac99altima View Post
strut mounts?
The whole strut assembly!!
post #14 of 16 Old 01-22-2009, 07:43 AM
2600 lbs
Quoted: 21 Post(s)
iTrader: 4 reviews
^i think he's asking you if the struts that you removed and are now not using have good condition strut mounts that he could buy off you.
post #15 of 16 Old 01-22-2009, 07:51 AM
vaxenzi's Avatar
the price for pair of springs is about 100$ including delivery
you should change both, because there may be different suspension coeficient between new and old springs, that can cause many problems during the drive
700$ this is stupid, it should be much more less
Georgia, Republic of
vaxenzi is offline
