Knocking noise under the car... - Nissan Forums : Nissan Forum
post #1 of 7 Old 01-23-2009, 08:30 AM Thread Starter
Lately I started hearing some kind of knocking noise under the car when I turn my steering wheel hard either way, more on slow speed like Parking or getting out of a parking spot. It all started after I got both my front CV shafts replaced at a local mechanic shop. I don't know if this noise has anything to do with CV shafts or not. Perhaps its just a coincidence..I read somewhere that u just need to grease the steering column..am little confused here.
Pls help me out here...
mastiff78 is offline
post #2 of 7 Old 01-23-2009, 10:29 AM
vaxenzi's Avatar
if the noise was something like ticking on slow speeds during the turn, this is really CV shaft
Georgia, Republic of
vaxenzi is offline
post #3 of 7 Old 01-24-2009, 03:01 AM
Selena
rtkskater44's Avatar
Quoted: 1 Post(s)
i have same problem, i think it might be cuz a retard at my cousins shop did it while i was doing a oil change on another car OR it could be an elbow on my exhaust since it comes close to the heat shield. either way its annoying and prevents me from romping the gas lol cuz im afriad something is happening
rtkskater44 is offline
post #4 of 7 Old 01-24-2009, 04:30 AM
My car did this and it sounded a little weird. Not a knocking noise but turned out I had a heat shield that had come loose. Check your exhaust Bang your muffler and see if it makes a noise.
adrenalex is offline
post #5 of 7 Old 01-24-2009, 03:47 PM
05 STi
Altima_Junkie's Avatar
Unless they were installed incorrectly, it wouldn't be the cv shafts becuase he just replaced them.
Is the noise coming from the front or back? and is it a steady knocking or does it only happen at a certain rpm range? is it a high-pitched knock/ticking/clattering or low-pitched?
Also if you just took it into the shop to have it fixed like yesterday, i'd recommend taking it back to the shop and recreating the problem to them and tell them it started happening right after you got the car back, tell them to fix it for free becuase they created the problem obviously.
Adios altima, Tis no more..
The new ride:
Tint, 3" TBE w/Megan Racing DP & Magnaflow muffler, TurboXs RFL bov, Injen CAI, Perrin manual boost controller
Originally Posted by eclypse
i see. so you bore the headers, and increase compression through the cams?
quit typing, start hitting the search button. honestly, it works. but hey what do i know, ill be out in the garage boring the headers on my Nova..
Altima_Junkie is offline
post #6 of 7 Old 01-25-2009, 03:16 PM
Whether they're new or not, it sounds like the outer CV joint on one of the sides.
2000 Altima SE
sstupid is offline
post #7 of 7 Old 01-25-2009, 03:49 PM
Selena
Quoted: 1 Post(s)
on my car, it may be my exhaust, i had too bang the heat shield in on an edge. im gonna bang it more when i get a chance, but check that if you have an exhaust
thtd be my first sight too look at
