How to manually open trunk - Nissan Forums : Nissan Forum
post #1 of 15 Old 01-30-2009, 06:04 PM Thread Starter
I lost my keys to my 1997 nissan altima. The Trunk release from inside the hasn't worked since i bought it (used). I have access to the trunk through the back seat but cannot figure out how to manually operate the latch.
Also, can anyone confirm if the door key is the same key as the ignition. I never used the key in the door because the previous owner installed an aftermarket keyless entry system.
Thanks for any help!!! (and i know i should have multiple spares, but they were lost in a recent move)
jahwarrior28 is offline
post #2 of 15 Old 01-30-2009, 07:20 PM
DIFFERENER
94sealtima's Avatar
unless they change the the locks on the car then yes the keys are?
Try it and see
TOUGE TERROR
_________________________________________
95 jwt ecu-$300 obo
GEORGIA MUSCLE BOI
A/C & H.I.D'S CREW MEMBER #1
contact me on FB "sean glover" or s240sxvsp3c@aol.com
94sealtima is offline
post #3 of 15 Old 01-30-2009, 07:41 PM
05 STi
Altima_Junkie's Avatar
There is no way to operate the latch manually from the outside without the key. That would defeat the purpose of a lock. yes ignition and trunk key are the same, unless as 94se stated they changed out the trunk lock.
Adios altima, Tis no more..
The new ride:
Tint, 3" TBE w/Megan Racing DP & Magnaflow muffler, TurboXs RFL bov, Injen CAI, Perrin manual boost controller
Originally Posted by eclypse
i see. so you bore the headers, and increase compression through the cams?
quit typing, start hitting the search button. honestly, it works. but hey what do i know, ill be out in the garage boring the headers on my Nova..
Altima_Junkie is offline
post #4 of 15 Old 01-30-2009, 08:18 PM
Try to fix the inside latch.
1994 Nissan Altima GXE (Ruby Pearl) Auto 200k, Bomz Short-Ram Intake, Alpine 9856 Head Unit w/iPod Interface, Infinity 6" x 8" REF6812CF (Front x 2), Infinity 6-1/2" REF6012I (Rear x 2), Lemans Champion HR 195/60/R15, NGK Wires/Plugs, Pilot Lighting PL-1055C Fog Lights, Depo Chrome Headlights
http://www.cardomain.com/ride/2382348
Special7 is offline
post #5 of 15 Old 01-30-2009, 08:43 PM
I'm sure he means open manually from inside the trunk, I hope, lol.
nissan_fx is offline
post #6 of 15 Old 01-30-2009, 08:44 PM
Originally Posted by nissan_fx View Post
I'm sure he means open manually from inside, I hope, lol.
I think there is bar inside which hold the latch. I will look in evening and let you know. Try to access the trunk from rear seat and see if you can see a hole or opening with a rod inside
zixy_tris is offline
post #7 of 15 Old 01-30-2009, 10:25 PM Thread Starter
LOL, yeah I'm trying to open the trunk from the gap in the middle of the backseat.
post #8 of 15 Old 01-30-2009, 11:06 PM
i highly doubt youll be able to get to it through the gap. if the seat doesnt fold down, youll likely have to remove it to have any chance of releasing it from inside.
RROCCO is offline
post #9 of 15 Old 01-31-2009, 03:35 PM Thread Starter
The middle of the seat folds down giving access to the trunk. Not large enough for an adult to squeeze through, but I child could. (or the long metal rod I plan to use).
post #10 of 15 Old 01-31-2009, 06:16 PM
Chea
jarell1944's Avatar
when i first got my car i thought the trunk release from the inside never worked beacuse when i pulled it it made no noise or anything..when i finally got the owners manual to my car i read that their is a little switch where the latch is that you push up and it lets you use the latch from the inside of the car...dont know if yours could be like this and you would be able to crawl in the trunk and try that.
i've also had to get in my trunk by removing the back seat and crawling in there...i think thats the only way...
ALTIMA UPGRADE GUIDE
93 Altima SE/5spd
jarell1944 is offline
post #11 of 15 Old 02-01-2009, 10:04 AM
See ya
iTrader: 3 reviews
^yep, its a security feature. You need to undo that latch and the inside lever will work.
Sassan is offline
post #12 of 15 Old 02-02-2009, 11:15 PM
theres a metal plate behind the rear seats with a few screws in it remove that panel and you can get into the trunk to reach that latch
....unless yer a skinny minnie like i was and can fit through that small hole lol
bodiddly is offline
post #13 of 15 Old 02-02-2009, 11:27 PM
2600 lbs
allblackedout111's Avatar
Quoted: 17 Post(s)
iTrader: 4 reviews
I hope my trunk latch on the inside doesn't break...I had my trunk latch shaved off of the trunk
allblackedout111 is offline
post #14 of 15 Old 02-09-2009, 07:06 PM
created with you in mind
jwizs23's Avatar
yea i had this problem and still do you have to remove the seat by opening both back doors then you will see a metal plate remove the screws from that and when that is remove, get into the trunk and you will see the level reach your hand where the level part is at the there is a bar pull it right and the trunk will pop open and then you can fix it im broke right now the reason why i havent fix my yet but this is my second one
jwizs23 is offline
post #15 of 15 Old 06-20-2014, 07:58 AM
glad I read this thread
I just bought a 97 altima gxe and the owner said the lever inside no longer worked. He had the car for 9 years, it's possible he never was able to use it as he was not aware of this magical safety latch inside the trunk. I moved it to the proper position and voila, my lever to the left of my driver seat works.
Thanks!
islstl is offline
