2000 Altima - Thermostat Replacement - Nissan Forums : Nissan Forum
Old 02-19-2009, 08:05 PM
Can somebody help me with a simple, detailed process on how to change the thermostat? Where it is located and whatnot.
Thanks
-Our Time Is Near-
Old 02-19-2009, 09:04 PM
fire's Avatar
East Los Customs
-Remove lower radiator hose, at the block.
-Remove the 3 bolts that hold the thermostat housing
-Remove "cover" and thermostat
-Clean old sealant off of both housing and "cover"
-Install new thermostat (make sure you put it in right, pay attention to how the old one was)
-add a new bead of sealant on cover and reinstall
Old 02-19-2009, 09:10 PM
Mr.Nissan's Avatar
Drain coolent by removing the plastic bolt on the rad,
using 10mm socket remove the housing and remove the thermostat
torque to spec!!!
Used to own a 93' Altima KA24DE!
Revenge feels so good!
Nissan Tech
Fix it now! When it is right, not when it is very $$$ to fix!!!
Old 04-11-2012, 07:44 PM
i pulled of the thermostat housing unit, and no thermostat was in there....
Old 04-12-2012, 08:18 AM
BiGJoHn619's Avatar
i believe the trq is like 66inch lbs or something i know im close to the number. very easy job make sure the nipple is pointing straight up. Also i suggest getting one from the dealer. all the other ones ive used are shit.
KA24DE-T
"The T stands for turbo, which translates to "im boosted bitches"
2001 - Stock Altima
2000 - Turbo'd Altima
Old 04-16-2012, 03:35 AM
Uh, well, someone removed it then?
It didn't come from the factory like that.
