Car Won't Turn over, battery is new - Nissan Forums : Nissan Forum
post #1 of 18 Old 09-14-2009, 11:53 PM Thread Starter
2nd Gen Boy
porschebk85's Avatar
Drove to work fine, went to start car at lunch and it unlocked with the remote, I got in and turned the ignition to start, and no-noise, just all the lights on like normal. I later tried to jump-start it even though I figured it wasn't the battery, and it wouldn't start like that either. I turn the key and just hear nothing, everything else works. It's sitting at work, and I can't afford top dollar to get it fixed. Any quick ideas?? Starter? or something else?
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
2006 Ford Fusion SE V6 - OEM Spoiler - 18" Konig Wheels
Proud Husband of an EMT-I/Firefighter
porschebk85 is offline
post #2 of 18 Old 09-15-2009, 12:20 AM
trebor8820's Avatar
Quoted: 2 Post(s)
If all of your accessories work and you are unable to jump it off, my guess would be either the starter or possibly even a battery cable. Usually when the starter croaks it will at least give you a click when you turn the key... my best guess would be the battery cables, particularly the ones to the starter. I would also check the starter itself for corrosion and a good connection on all plugs/connectors.
If it is your starter, you might be able to disassemble the starter solenoid (haven't looked at these Nissan starters, so I'm not sure how feasible this actually is) and clean the contacts inside of it. When these contacts become corroded or otherwise dirty, they can cause the starter to fail. By cleaning them up real good and cleaning the plunger, usually you can get several more months of life out of the starter.
2000 Nissan Altima GXE 5 Speed 279,000M - R.I.P.
2002 Ford Mustang 3.8l 121,000M
2006 GMC Yukon SL 4.8l 110,000M
trebor8820 is offline
post #3 of 18 Old 09-15-2009, 12:26 AM Thread Starter
2nd Gen Boy
Yeah the battery and battery cables were all replaced by Nissan in April of this year. I've checked the cables and they are tight, and everything seems to be getting power. It's just the car isn't even making any electronic noises at all. It's just as quiet as it is sitting there, as it is when I turn the key. And the I've only grinded the starter once in the whole time I've owned the car. I wish my mechanically inclined friends lived around here.
post #4 of 18 Old 09-15-2009, 12:30 AM
trebor8820's Avatar
Quoted: 2 Post(s)
That also sounds like it could be a relay. I don't see a starter relay on this car, though I did find a "Starter Signal" fuse in the fusebox under the hood. It's a 10A fuse located in the middle toward the bottom of the fuse panel; check it out, make sure it isn't blown.
post #5 of 18 Old 09-15-2009, 02:59 PM
The Don.
Quoted: 5 Post(s)
Its possible that the starter solenoid is not getting power. The issue could be coming from the parking/neutral interlock switch or clutch interlocking for M/T. You have to determine whether the starter solenoid is getting power and then take it from there.
'94 Nissan Altima SE, 5spd.
ITEMS FOR SALE
jserrano is offline
post #6 of 18 Old 09-15-2009, 04:27 PM
Try this! When car is stopped, turn on the headlights and ask some friend to try starting it, while you'll be watching the headlights. If while trying to start your lights don't dim, then you have a starter problem.
Also see these threads:
http://www.nissanclub.com/forums/gen...ust-click.html
http://www.nissanclub.com/forums/gen...ont-start.html
Good luck.
19marius73 is offline
post #7 of 18 Old 09-16-2009, 02:18 AM Thread Starter
2nd Gen Boy
Decided to have it towed to shop near my home, was quoted 290 for starter install. I decided I'll lose more money because I can't get to work, so I might as well get it done right away. Just pissed, I already spent good money a week ago getting the knock sensor replaced.
post #8 of 18 Old 09-16-2009, 02:24 AM
290 sounds on the low side for this job. They're going to put you a crappy starter, you'll be back in business in a year. take care.
post #9 of 18 Old 09-16-2009, 02:26 AM Thread Starter
2nd Gen Boy
^ These guys are decent, they're just cheaper on the labor side. I've never had an issue with them yet.
post #10 of 18 Old 09-16-2009, 02:31 AM
Well, I say that because I installed myself a new starter on my Altima 98 (198 kmile) last week and only the starter was 250 bucks. I spent about 3 hours to do the job so you could compute what labor is in $. You might be right, though I am in Canada.
post #11 of 18 Old 09-16-2009, 02:48 AM Thread Starter
2nd Gen Boy
oh wow 250, I looked at a brand new TYC OEM one for 80 new.
post #12 of 18 Old 09-16-2009, 02:52 AM
Selena
rtkskater44's Avatar
Quoted: 1 Post(s)
could it be the chip in the key? may have gone bad
Follow my build on Instagram (https://instagram.com/r_kaye44/) or Facebook (https://www.facebook.com/rkaye3)
Current cars:
1999 BMW 328i (Daily)
1997 Jeep Wrangler (Offloading)
2000 Nissan Altima (Project)
rtkskater44 is offline
post #13 of 18 Old 09-16-2009, 03:05 AM
Wow, that doesn't sounds right. Only the core return is about 80 bucks. Even the cheapest starter is about 120 USD. But maybe I am wrong, I don't want to discourage you. Well I bought a Bosch OEM all brand new. They say it exceeds OEM, whatever. I hope you'll be good for less money than me.
post #14 of 18 Old 09-16-2009, 04:13 AM
trebor8820's Avatar
Quoted: 2 Post(s)
If the chip in the key goes out (or isn't present) it will still allow the car to start up, but it will immediately die out.
Someone mentioned the park/neutral switch - I didn't think about that, but I agree it sounds very much like it could be the issue.
If it makes you feel any better about spending about $300 on the starter, I brought my altima in today to have the A/C checked out and apparently my compressor blew and it screwed up my entire A/C system... I'm shelling out $1300 to get it fixed.
post #15 of 18 Old 09-16-2009, 01:39 PM
now I feel good about spending only 300 bucks. I seem to have some A/C problem. Sometimes it works, sometimes it doesn't. I wonder if I overfilled it with refrigerant, though it was even worse before refilling. Any idea what should I check?
