Error P0420 vacuum leak? - Nissan Forums : Nissan Forum
post #1 of 12 Old 10-30-2009, 12:59 PM Thread Starter
Trav-0's Avatar
Okay, so my check engine light came on at 128000 miles in my 2001 Altima. The car has been running like a champ despite some unrelated suspension issues.
The error code I get is a P0420 Catalyst system efficiency below threshold.
The car has been burning a little bit of oil and at the time I checked it was actually about 1/8 quart over which I could probably attribute to expansion due to heat. Other than that I haven't noticed any rotten egg smell from the tail pipe and everything seems to be running correctly.
The probable cause here says.
Large Vacuum Leak
Fuel System Fault
Ignition System Fault
Failed Bank 1 Catalytic Converter
I am limited in knowledge but can handle everything but the vacuum leak.
#1) Where are ALL the vacuum lines to check
#2) How do I check them
#3) If leak is found how do I replace them
I have the Nissan factory manual, the good one for mechanics, but can't seem to find where the vacuum lines are,
Any help is greatly appreciated.
Trav-0 is offline
post #2 of 12 Old 10-30-2009, 03:46 PM
Selena
rtkskater44's Avatar
Quoted: 1 Post(s)
i highly doubt it would be vacuum leak... unless you see fluctuation in your idle / poor gas mileage, it would be a clogged cat or sumthing along the exhaust.. maybe bad 2nd o2 sensor... do u have headers or is your car complete stock?
Follow my build on Instagram (https://instagram.com/r_kaye44/) or Facebook (https://www.facebook.com/rkaye3)
Current cars:
1999 BMW 328i (Daily)
1997 Jeep Wrangler (Offloading)
2000 Nissan Altima (Project)
rtkskater44 is offline
post #3 of 12 Old 10-30-2009, 03:51 PM Thread Starter
Trav-0's Avatar
This car is totally bone stock, I aim to get the thing in the air and check the secondary O2 sensor sometime tomorrow or Sunday with a multimeter.
There is no fluctuation in the idle but it sounds like there is some back pressure in the exhaust with lots of black soot on the end of the muffler. The gas mileage has been an issue since I have owned the car, but since my inspection expires at the end of the month it has kind of become an issue to get that CEL off.
Please advise? Thanks again.
Oh, the only reason why I suggest vacuum is because it is the thing I know the least about and figure it can't hurt to check it.
Trav-0 is offline
post #4 of 12 Old 10-30-2009, 04:08 PM
The Don.
Quoted: 5 Post(s)
With your issue the term "vacuum leak" is incorrect. It should say, "exhaust leak".
An exhaust leak can play havoc with the front or rear O2 sensor. If those sensors are reading incorrect data then the diagnostic that goes out to check the condition of the catalytic converter will also report a false code.
The easiest way to pinpoint an exhaust leak is to have someone cover up the tailpipe with some rags while you listen closely along the exhaust pipes.
'94 Nissan Altima SE, 5spd.
ITEMS FOR SALE
jserrano is offline
post #5 of 12 Old 10-30-2009, 04:11 PM
Selena
Quoted: 1 Post(s)
welcome jserrano =],
he is our premium mech diagnostic specailist, he came. he saw. he conquered..
everyone give him a round of applause!!!
thank you thank you
Current cars:
post #6 of 12 Old 10-30-2009, 04:25 PM
The Don.
Quoted: 5 Post(s)
thank you thank you
Damn, I hadn't noticed I gained that much notoriety.
Actually, I only understand some areas more than other, and mainly they have to do with electrical or electronic control systems. If I were ever to enter into the auto mechanics field it would have been as a Drivability Technician. But I enjoy my work as a Database Administrator too much. I guess this is good enough for me as a hobby.
ITEMS FOR SALE
jserrano is offline
post #7 of 12 Old 10-30-2009, 05:17 PM Thread Starter
Trav-0's Avatar
Well thank you jserrano and rtkskater44 I will take a look and see what I can figure out. If this doesn't help to alleviate the problem I know I will be back but this at least will give me a good start on what to look for.
Trav-0 is offline
post #8 of 12 Old 07-01-2011, 12:30 AM Thread Starter
Trav-0's Avatar
Turned out to be a bad catalytic converter. In the meantime I replaced both o2 sensors, cleaned the EGR, tracked all the vacuum lines down and put about 25,000 on her.
Trav-0 is offline
post #9 of 12 Old 07-02-2011, 03:51 PM
97AltimGXE
1997GXE's Avatar
which cat was it? i have the same code also...the 02 sensors were changed in 2006....
Mod List
Place Racing Intake with k&n filter
SE Sides
Erebuni 905 rear
Falken Ziex ZE-912
98 alty 6 spoke alloy rims
UR Pulley
JDM smoked tail lights
IBI Eyelids
93-94 Grill
* New Pics to come Soon*
1997GXE is offline
post #10 of 12 Old 07-04-2011, 09:47 PM Thread Starter
Trav-0's Avatar
There is only one that is integrated into the header. Mine is not a CA model.
These engines if driven into the high 4000's can and will burn out the cat. The catalyst will melt and it will clog. It's a piss poor design. If you can and have all the tools you can get an inline one for much cheaper but you will need to cut and weld and hope that you have enough slack in your secondary o2 sensor to get it to fit in still.
Much less work just pulling the fan shroud and fans, removing heat shield, taking header bolts out, disconnecting all the bottom of the pipe, removing primary o2 sensor (better safe than needing a $60 o2 replacement), loosening the alternator and getting the 6 bolts that old the cat on. If you do it you will need a 10, 12, 14, and 15 mil socket and 2 8" extensions at the very least.
Best way to tell if you need a cat is to ride behind yourself and see if it smells like rotten eggs. If it does then you will need a new cat. Course... you can't follow yourself so just have someone else drive and follow.
Hope that helps.
Trav-0 is offline
post #11 of 12 Old 07-05-2011, 01:42 AM
97AltimGXE
1997GXE's Avatar
hey thanks for the info... it doesn't smell like rotten eggs.. last year the same code came on but went away within a few weeks. should i change my 02 sensors....
Mod List
SE Sides
Erebuni 905 rear
Falken Ziex ZE-912
UR Pulley
IBI Eyelids
93-94 Grill
1997GXE is offline
post #12 of 12 Old 07-05-2011, 02:02 AM Thread Starter
Trav-0's Avatar
Guess that depends on how many miles since you replaced them in 2006. Usually if it's an o2 sensor it will be a code that is specific to the o2 sensors. Something like a P0130-P0167 which would indicate that an o2 sensor is bad.
A P0420 could be an indicator of what was mentioned above. What I would do is get some spark plug anti-foulers and use those to fool the computer.
If you follow the guide below be warned that it is a temporary solution but costs very little. If the light goes out I would lean towards replacing the catalytic converter. If it doesn't I would say that it is possible that you have an exhaust leak or a vacuum leak.
Guide --> http://www.energeticforum.com/renewa...n-foulers.html
List of codes --> OBD-II Check Engine Light Trouble Codes
If I recall correctly your secondary o2 sensor on that car is a weird size that a sparkplug anti-fouler will not work. If that is the case then you need to find another way.
Trav-0 is offline
