-get a marker, and tape it up to match holes inside trunk and point str8 and mark
-i cut the wires and put it together
sorry i might confuse you, i mean how do u know you are marked on the holes inside the trunk? Like mark and drill from the trunk side?
I have a 94 altima, im not sure does the wires work at the same color?
And tape the whole spoiler or just on position and drill?
Sorry im a little stupid and still working on my english
If you can list the detail steps i would appreciate that
Now:NGK spark plug &wires set ,Aftermarket intake
Coming up soon: NOt sure
My first time makin a diy, so correct me if im wrong, if u have questions feel free to ask..
Materials
-spoiler
-wire-any gauge wiring
-smirnoff
-drill
-drill bit
-music
MOST IMPORTANTLY HAVE THE RIGHT DRILL BIT TO CUT THRU METAL
gET SOMETHING WITH A POINTY EDGE SO U CAN MAKE A BUMP SO THAT WHEN YOUR DRILLING IT DOESNT GO ALL OVER TH EPLACE AND STAYS IN ONE SPOT
BEFOREEEEEE
dURINGGG
use a sharpie
had to cut a bit more cudnt get the socket in the hole( thas what she saidd) wiring-connect it to the brake light or if u have a third brake light
splice open both wires and join duhhhh
green/yellow-POWER WIRE(use)
BLack-Groungd wire(use)
Black/red wire- parking lights (do not use)
be sure when u gett the spoler get the harness also (none of the models come with it)..i cut mines off the donor car
aFTERR IL ALLL DONE
yo this came out looking good. Good job on explaining this. lol. Should have sealed the holes though =-)
__________________ -2001 Nissan Altima gxe Limited-
A.I. Lowering Coil over sleeves,
2.25" Cat back Exhaust.
4" Performance Muffler,
Spectre 3" Short Ram Air Intake,
NGK Wires-Plugs. 15" EnKei Rims.
ohh, this is for 99 bro...ive never actually seen a 94 altima from the inside, 99 altima had the places already, i jus had to mark the sheetmetal inside the trunk frame
Its the same thing for 1st gen's. Pretty much if you puncture perfectly in the middle of those holes your good to go. That's what I did, took me a little under one hour. Still got to wire the LED light though.
OMG, did TWO people really quote the entire original post?
And it looks goods man, I feel like it's off center though. Looks like it's too far to the passenger side of the car, by about an 1/8th of an inch.
AngryBot: Well when two admins fall deeply in love...they can't physically have children so they adopt one and that's how a moderator is made.
Pulski: Just because you have a less slow car than some here, doesn't make you any less of an idiot.
Or is it just the angle of the picture? I notice your rear picture you are standing a little towards the drivers side of the car making the spoiler look like its off to the passenger side. I donno, could be my eyes playing tricks on me
its not bro, it dead right in the center, its the angle..my dads n architect he helped me make the marks
I just wanted to add to the DIY, if you don't want to cut your harness to your 3rd brake light for any reason, you can use Auto-Tap Connectors. Here is a link to buy them (and a picture to look at if you want to buy it at your local auto store.
Here is a quick picture I made to demonstrate how they work.
There are two holes on the connectors, one that goes straight through and one that is blocked halfway. For the one that goes straight through, you lace through the stock harness and for the that is blocked, you put the spoiler wire in that one and crimp/push down the metal connector. That is the way I connected it, I'll try to take a picture of mine.
