Brake Lights not working - Nissan Forums : Nissan Forum
post #1 of 7 Old 12-14-2009, 02:49 PM Thread Starter
cwarnar's Avatar
I noticed this morning that my brake lights are not functioning on my 98 Altima GXE. When I turn the park lights on, the taillights come on but do not light up when the brakes are applied.
I think it may be a bad fuse but did not see brake lights on the fuse panel.
Any suggestions?
cwarnar is offline
post #2 of 7 Old 12-14-2009, 03:16 PM
singhz4lyfe's Avatar
Originally Posted by cwarnar View Post
I noticed this morning that my brake lights are not functioning. When I turn the park lights on, the taillights come on but do not light up when the brakes are applied.
Any suggestions?
when i was installing my factory foglights i spliced then into my parking lights, turned em on and the fuse blew so replaced the fuse
its the GREEEN one BTW- it functions the cluster/brake/parking lights THIS IS FOR 1999 NISSAN ALTIMA
singhz4lyfe is offline
post #3 of 7 Old 12-14-2009, 03:21 PM Thread Starter
cwarnar's Avatar
Gotcha... I will check it out... I was looking in the dash fuse area not the one under the hood. I will see if that one is blown.
Thanks.
cwarnar is offline
post #4 of 7 Old 12-14-2009, 03:58 PM Thread Starter
cwarnar's Avatar
I was able to locate the 15A fuse for the stop lamps but they are still not working and I have blown 2 fuses since replacing them only seconds later.
Now what????
cwarnar is offline
post #5 of 7 Old 12-14-2009, 04:06 PM
You have a short somewhere in your brake light wiring - check the harness inside the light assembly, maybe water leaked in or check the brake pedal switch harness
faja is offline
post #6 of 7 Old 12-14-2009, 04:07 PM Thread Starter
cwarnar's Avatar
Will do.
cwarnar is offline
post #7 of 7 Old 12-23-2009, 05:42 PM Thread Starter
cwarnar's Avatar
Turns out out when I installed my spoiler I did not protect the new wiring. Problem found... problem fixed.
cwarnar is offline
