The 1st & 2nd Gen. Lounge! (General Discussion) - Page 5 - Nissan Forums : Nissan Forum
  #61 (permalink)
Old 04-30-2010, 12:02 PM
ALTIMA24's Avatar
Noir Mat
^who would BS about splicing a wire? this is a well known FREE mod who needs to lie about it?
Rear Foglights FTW
1999 Nissan Altima SE-L
Taz Racing Racing MMI's-Short Shifter-8000k HID-Amber Parking/Fogs-Rear Foglights-Accord Lip-Zenn Lowering Springs-Magnaflow Exhaust-Brakemotive Cross drilled/Slotted Rotors Evolution Pads
Under construction
  #62 (permalink)
Old 04-30-2010, 12:24 PM
que es un altima?
Drop Resistor Mod
  #63 (permalink)
Old 04-30-2010, 01:42 PM
Jae413's Avatar
Project Jae Spec
Grazie mille!
Originally Posted by allblackedout111 View Post
Make sure you guys are starting with no initial preload on the swaybar.
now i understand why the drivers side, rear endlink adjusted on its own. i have been tossing her around in turns a bit, not much, waiting on the d2's to really push her to her limits. but since its only me in the car - thats causing the balance to be off since i have no passenger, resulting in the driver's side rear endlink self adjusting due to preload/installing everything while the car was jacked up.
so if you drive mostly alone, then its wise to leave the rear drivers side endlink a little longer. heard anything on that Jay?
hmmm, wonder if that would apply to the front endlinks (not installed yet though). factoring in cross section, would i have to leave the passenger side front endlink longer Allblack?
back to reading some more...
Stage III "MO POWAH to the wheels"
Shout out to NissanClub for the knowledge
proud member of "Got balls to rock the right rim size" Club!
  #64 (permalink)
Old 04-30-2010, 06:52 PM
jayjaya29's Avatar
///M Time!
iTrader: 3 reviews
Originally Posted by Jae413 View Post
now i understand why the drivers side, rear endlink adjusted on its own. i have been tossing her around in turns a bit, not much, waiting on the d2's to really push her to her limits. but since its only me in the car - thats causing the balance to be off since i have no passenger, resulting in the driver's side rear endlink self adjusting due to preload.
I only weigh 140lbs, not much in comparison to the rest of the car. So I keep the endlinks at equal length for both sides.
Click to see more!
2000 Nissan Altima GXE
-Eccho's TB Spacer
-Hotshot CAI
-Vibrant FSTB
-UR Pulley
-ST Rear Sway Bar
-Liquid Ink A-Arm Brace
-Hotshot Headers
-Spec-V Rims
-Rear Disc Brakes
BUY MY STUFF!
  #65 (permalink)
Old 04-30-2010, 07:42 PM
Jae413's Avatar
Project Jae Spec
^ true, i'll try leaving one side longer & test it out.
as for your next auto x'ing run, dont do it, let the cams break in and get her running tight for the following event. they make you wear a helmet right? how many cones you ran over? dont lie now...lol. or was it a track?
  #66 (permalink)
Old 04-30-2010, 08:04 PM
allblackedout111's Avatar
2600 lbs
iTrader: 3 reviews
You don't adjust the sway bar to compensate for the driver.
You're end link should not have adjusted itself in any way.
To keep preload off the sway bar, you need to have the car on the ground without the sway bar end links attached, and attach them evenly on both sides, keeping the sway bar holes at a parallel angle to the floor (at least for a first gen, the second gens are probably around a 45 degree angle with the floor)
  #67 (permalink)
Old 04-30-2010, 11:26 PM
Natethagreat's Avatar
Not Another Altima...
hmmm, i thought kepping preload off means raiding the car so there is no weight pressing down. so keep the car on the ground then? or was it a typo...
i cant wait to get these on!
99' Nissan Altima GXE
  #68 (permalink)
Old 04-30-2010, 11:58 PM
Jae413's Avatar
Project Jae Spec
got it allblack, going to try that this weekend then. I read both ways, what you mentioned & keeping one side a lil longer.
Nate, yeah, keep it on the ground. but Jack the car to install your bar 1st, attach the endlinks at the strut but not the sway bar. then lower it with wheels on. get under her and adjust the endlinks so that they will slide right on the top notch of the st bar. that's the hole going towards the bar. tighten them up and bam! your starting with no preload. I think, from what I've learned in the past 2 days.
I went wrong by installing everything while the car was jacked. noob mistake, on top of that I placed one of the poly bushings on the wrong end. I rushed the install cause security in my community was on my ass - wasn't suppose to work on the car in the parking lot.
  #69 (permalink)
Old 05-01-2010, 06:35 AM
EA11R's Avatar
Vitamin L30
Why does the end link length have any effect upon anything? I assume that changing the length changes the effectiveness of the bar, but I don't know which direction does which and can't figure out why. Anyone care to explain? I just finished placing an order for some Racing Beat endlinks, so I figure I should learn what all this crap means.
While I'm at it: How on earth do you 'preload' a FSTB?
1999 Altima GXE 4AT.
eBay strutbar, LI A-arm brace, Racing Beat rear endlinks, SS rear brake lines
ES A-arm bushings, ES RPL bushings, ES swaybar bushings, Eibachs on Tokicos
RLR Motor Mounts, Speeeeeeeeeeeeeeeeedline wheels
  #70 (permalink)
Old 05-01-2010, 09:03 AM
Jae413's Avatar
Project Jae Spec
according to redlion, to preload a fstb you adjust it to the point where it's pulling on the strut towers or pushing them. obviously it has to be an adjustable fstb, my oem fstb isn't I believe. caught that searching through the forum.
lengthening/shortening the endlinks seems to have the same effect on the sway bar from what I gather. this can compress it like a spring I think, making it a bit stiffer - I'm no expert mind you so I'm not 100% sure but kinda makes some sense. in which direction depends on your set up I think, how low you are and which sway bar your rocking. someone with more knowledge care to elaborate? search the net kid! I did, type "swaybar preload" in the google search window. there's loads of info out there. very interesting stuff, just takes a little time to understand it.
  #71 (permalink)
Old 05-01-2010, 08:14 PM
hmmm so lower it all the way down? i.e no jack needed no more?
and...
does anybody know a good cheap site to buy oem front and rear control arms? preferably new. cuz i need to replace al mine :/ and are racinglines fron endlinks help as much as the rear endlinks?
  #72 (permalink)
Old 05-01-2010, 09:46 PM
Jae413's Avatar
Project Jae Spec
from what I understand, yeah Nate.
jack the car, remove the wheels. then remove your old set up, install your new set up BUT don't attach the endlinks to the sway bar! do that after you've put your wheels back on & removed the jacks. you should be able to adjust the endlinks so that they will attach easily. I hope! going to do mine tomorrow.
our rides from factory are set up so the the front sway bar is thicker than the rear I believe. might be the same for the endlinks too. I haven't really looked at my front ones but I'm willing to bet either way it would be worth it to replcae them also.
  #73 (permalink)
Old 05-01-2010, 11:17 PM
jayjaya29's Avatar
///M Time!
iTrader: 3 reviews
You guys are putting wayyy too much thinking into this whole endlink setup.
Just install the endlinks while the car is jacked up. It makes no difference, because as soon as the car is on the ground the sway bar and endlinks will move into the correct position...
  #74 (permalink)
Old 05-01-2010, 11:38 PM
Jae413's Avatar
Project Jae Spec
in my case that's exactly what I did jay. but now I have one endlink much longer than the other. so I want to reset it by trying this way of avoiding preload and see if it happens again.
  #75 (permalink)
Old 05-02-2010, 12:19 AM
jayjaya29's Avatar
///M Time!
iTrader: 3 reviews
The endlink extended on you because you didn't tighten the two nuts that hold the center shaft in place.
Powered by vBulletin®. Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
