Tdc - Nissan Forums : Nissan Forum
post #1 of 9 Old 05-12-2010, 08:46 PM Thread Starter
all blacked out
itwillrun's Avatar
Quoted: 2 Post(s)
Tdc
We use the crank to turn the timing chain to reach TDC correct, the mark we use of the chain though is which one ?
itwillrun is offline
post #2 of 9 Old 05-12-2010, 09:39 PM
///M Time!
jayjaya29's Avatar
Quoted: 1 Post(s)
iTrader: 3 reviews
Cams of the 1st cylinder will be pointing AWAY from the center of the engine.
Click to see more!
2000 Nissan Altima GXE
-Eccho's TB Spacer
-Hotshot CAI
-Vibrant FSTB
-UR Pulley
-ST Rear Sway Bar
-Liquid Ink A-Arm Brace
-Hotshot Headers
-Spec-V Rims
-Rear Disc Brakes
jayjaya29 is offline
post #3 of 9 Old 05-12-2010, 11:39 PM Thread Starter
all blacked out
itwillrun's Avatar
Quoted: 2 Post(s)
The intake, exhaust, or both? And thanks.
post #4 of 9 Old 05-13-2010, 12:48 AM
slowly losing my sanity..
phreekee25's Avatar
in case you need the service manual: Nissan Service Manuals
on my QR, it is both cams of first cylinder that point outward when tdc.
phreekee25 is offline
post #5 of 9 Old 05-13-2010, 02:41 AM
///M Time!
jayjaya29's Avatar
Quoted: 1 Post(s)
iTrader: 3 reviews
Both will point outward.
Click to see more!
-Eccho's TB Spacer
-Hotshot CAI
-Vibrant FSTB
-UR Pulley
-ST Rear Sway Bar
-Hotshot Headers
-Spec-V Rims
-Rear Disc Brakes
post #6 of 9 Old 05-18-2010, 08:00 AM
Premium Member
BiGJoHn619's Avatar
Quoted: 6 Post(s)
please do not **** this up like i did my first time... take cyl one plug out and stick a screw driver in there and turn crank to tdc the piston will be all the way up. both cams will be pointing away like this <- -> then you know ur at tdc...
KA24DE-T
"The T stands for turbo, which translates to "im boosted bitches"
1991 - 240sx KA24DE-T 308whp 296wtq @ 12lbs
2000 - Altima KA24DE-T 372whp 338wtq @ 16lbs on e85
2001 - Altima STOCK Daily
BiGJoHn619 is offline
post #7 of 9 Old 05-18-2010, 09:54 PM Thread Starter
all blacked out
itwillrun's Avatar
Quoted: 2 Post(s)
I did, I had it set right but than when I was trying to break lose the cams it shifted a bit. It wasn't alot so hopefully it will be okay.
post #8 of 9 Old 05-19-2010, 05:55 AM
DIFFERENER
94sealtima's Avatar
did imove before you put the chain on? are did it happen while the chain was on?
TOUGE TERROR
_________________________________________
95 jwt ecu-$300 obo
GEORGIA MUSCLE BOI
A/C & H.I.D'S CREW MEMBER #1
contact me on FB "sean glover" or s240sxvsp3c@aol.com
94sealtima is offline
post #9 of 9 Old 05-19-2010, 11:16 PM Thread Starter
all blacked out
itwillrun's Avatar
Quoted: 2 Post(s)
I took the timing chain off and i think it might have been than that it happened.
