Vacuum leak from fuel injector - Nissan Forums : Nissan Forum
post #1 of 3 Old 10-17-2010, 07:38 PM Thread Starter
A couple weeks ago I replaced the intake manifold gasket on my 2000 Altima. Since this was my first time working on a Altima I pulled the fuel rail from the car. After I replaced the intake gasket, I now have a vacuum leak from the injector down at the intake. I used thr Fel-pro kit HS9942 PT-1 that had the fuel injector insulators. These insulators looked more like an o-ring vice the flat insulators that I removed. I can get the car to run correctly if I install the new insulator along with the old insulator. Or if I removed the plastic spacer (fuel tube spacer) from the two mounting bolts on the fuel rail. I have order new insulator 16636-5E512 from Nissan and still have the same vacuum leaking problem. I am mounting the fuel rail as follow: Intake manifold, fuel tube space, fuel rail and bolt. Can anyone help me resolve this problem.
cobra79 is offline
post #2 of 3 Old 10-24-2010, 01:32 AM
The Don.
Quoted: 5 Post(s)
Those o-rings were probably meant for the top o-ring of the injectors vice the insulators.
'94 Nissan Altima SE, 5spd.
ITEMS FOR SALE
jserrano is offline
post #3 of 3 Old 10-28-2010, 10:58 PM
Selena
rtkskater44's Avatar
Quoted: 1 Post(s)
100% correct.
Follow my build on Instagram (https://instagram.com/r_kaye44/) or Facebook (https://www.facebook.com/rkaye3)
Current cars:
1999 BMW 328i (Daily)
1997 Jeep Wrangler (Offloading)
2000 Nissan Altima (Project)
rtkskater44 is offline
