Spark Plug for Nissan Altima 2000 GXE - Nissan Forums : Nissan Forum
post #1 of 6 Old 01-01-2011, 10:32 PM Thread Starter
I have got Nissan Altima 2000 GXE and would like to replace all spark plugs. Which spark plug do you guys recommend? I am confused between PFR5G-11( standard) and PFR6G-11(cold). Thanks for any help.
PS: Also do you all think I need to replace my fuel filter? I am running at 110K miles now.
sagarghimire is offline
post #2 of 6 Old 01-01-2011, 11:21 PM
Spec R
Jae413's Avatar
Quoted: 1 Post(s)
young grasshopper...
this is a waste of a thread. this info can be found easily via a search.
NGK V Power is what you want to run. toss that platinum idea out your head. the copper ones will serve you well. no need for platinum/iridium types. unless your the lazy type that doesn't like doing their own tune ups.
RockAuto.com - in case your wondering where to shop for the lowest prices
change out the filter too! might aswell. if your doing it yourself, you should buy some back up fuel hose n clamps. in case you have to cut the old one in order to take out the stocker.
try using plyers to break the stock hoses loose, twist em till it's free. Blackalti used wd40 to do this, as they are stubburn fukcers
Stage III "MO POWAH to the wheels"
Shout out to NissanClub for the knowledge
proud member of "Got balls to rock the right rim size" Club!
Jae413 is offline
post #3 of 6 Old 01-01-2011, 11:37 PM
93 altima stock
dukes187 is offline
post #4 of 6 Old 01-02-2011, 01:03 AM
haha you guys are so not nice at all
hahah good times guys good times
96ka24de(t)inalil is offline
post #5 of 6 Old 01-02-2011, 03:33 AM
Vitamin L30
EA11R's Avatar
Even better answer: Autozone part number 6953. $2.29 per plug. Go, buy.
1999 Altima GXE 4AT.
eBay strutbar, LI A-arm brace, Racing Beat rear endlinks, rear disc brakes
ES A-arm bushings, ES RPL bushings, ES swaybar bushings, Megan Racing coilovers
RLR Motor Mounts, Speedline wheels
EA11R is offline
post #6 of 6 Old 01-02-2011, 02:35 PM
Retired 2nd Gen'er.
BeeCee's Avatar
Quoted: 38 Post(s)
6953 Is the alternate part # for what Jae mentioned, NGK V Power: BKR5E.
So yes, you want NGK BKR5E's (same thing as 6953).
Please search next time.
Now, to close this waste of a thread.
The Alt.
1999 Nissan Altima GXE, RIP
2015 4-Door Si
'Members Ride' Thread
Parts FOR SALE! (UPDATED: 9/19/15)
BeeCee is offline
Closed Thread
