Code 1446 and gas filling problem...HELP! - Nissan Forums : Nissan Forum
post #1 of 9 Old 02-25-2011, 05:44 PM Thread Starter
My '00 GLE is throwing the P1446 code and when I'm trying to fill up the tank, the pump shuts off every gallon or less.
I've changed the Canister Vent Valve (originally I incorrectly said it was the purge solenoid)($100) because the old one was intermittent when testing it (the valve would work once then not again for like 10 seconds). I drove it for a couple days and then it threw the code again. I've taken the canister down and nothing came out of it but I didn't do much with it. I blew out the water separator and there was foam that came out of it, was that incorrectly done? Could the canister be bad? This is a Texas car, so I'm doubting the filler neck is rusted out (it doesn't look bad).
What else can I check?
Thanks for any help!
Kyle
EDIT - I replaced the Canister Vent Valve, the one attached to the charcoal canister.
agkyle is offline
post #2 of 9 Old 02-26-2011, 02:44 AM
... don't get caught
UhOh's Avatar
Quoted: 10 Post(s)
1997 Altima, 5-speed;
158,000 miles.
UhOh is offline
post #3 of 9 Old 02-26-2011, 07:23 AM
2600 lbs
allblackedout111's Avatar
Quoted: 17 Post(s)
iTrader: 4 reviews
The vent control valve is stuck closed. I honestly don't know the exact location of this on your car, but that is the cause of your issue.
allblackedout111 is offline
post #4 of 9 Old 02-26-2011, 04:02 PM Thread Starter
Is the vent control valve the one in the tank? I guess I'd need to drop the tank to check that?
The only problem is here in Dallas to pass inspection there can't be any codes being thrown and I am also trying to sell this car. It might be in my head but I think the gas mileage goes down quite a bit when the light is on, too. Does this run in a "limp" mode when that code is thrown? Or is that just me?
agkyle is offline
post #5 of 9 Old 02-26-2011, 04:25 PM Thread Starter
Maybe I got the wrong name for the part I replaced. I replaced the Canister Vent Valve, the one attached to the charcoal canister. I was thinking they called that a purge solenoid, but I guess not.
agkyle is offline
post #6 of 9 Old 02-26-2011, 10:56 PM
2600 lbs
Quoted: 17 Post(s)
iTrader: 4 reviews
Do you have a way to clear codes yourself? If so, try riding around with the gas cap loose, it may throw another code, but if you can erase it then you don't have to worry. You can determine from this if you gas tank is properly venting/creating vacuum, if the other code goes away.
It seems you may have already replaced the vent valve....if you are throwing a code for it, is it possible you put it in backwards? I'm not familiar with them on this car, so I'm not sure if they can be reversed.
I'm still not sure about the foam coming out of the water separator.
post #7 of 9 Old 02-28-2011, 06:56 PM Thread Starter
Yeah, I'm working at my family's shop and we're using a snap-on computer scanner. I've reset the code everytime it shows up.
I refueled today and after 2 gallons it squirted gas out everywhere. Slowed the pump down to the lowest and it stopped only once.
Are the "water separator" and the "refueling control valve" the same thing? We use ALLDATA repair software here and it shows those as being different components but they look the same. I might have blown the foam out of the "refueling control valve". The foam was like a deteriorated filter inside the component.
agkyle is offline
post #8 of 9 Old 02-28-2011, 07:01 PM Thread Starter
Here's a pic of what I'm looking at now. This looks like I was probably NOT messing with the "refueling control valve" because the thing I messed with was down by the canister behind the tire.
agkyle is offline
post #9 of 9 Old 03-08-2011, 05:36 PM Thread Starter
Ok, so I tried driving with the gas cap loose. Loose enough to smell gas when getting out of the car and it took 3 days and getting up to 70mph to make the light come on this time. Same code, 1446.
Then when I tightened the cap back up after clearing the code, it came back in the same day. UGH! What would cause that light to CONTINUALLY come on?!? Is the gas cap actually bad??
agkyle is offline
