Crank Position Sensor Codes: P0335 and P1336 - Nissan Forums : Nissan Forum
post #1 of 6 Old 06-02-2011, 09:38 PM Thread Starter
On my '96 Altima (auto trans), I'm getting codes 0335 and 1336, which I see are both related to the Crank Position Sensor. I know that the CPS is only used to detect misfires, so my question is:
Are these codes being set because the ECU detected a misfire, or because the Crank Sensor and/or its wiring are bad?
Thanks.
Robustus is offline
post #2 of 6 Old 06-03-2011, 03:18 AM
The Don.
Quoted: 5 Post(s)
No, it doesn't have anything to do with an engine misfire. The problem is located somewhere with the CPS sensor, its wiring, or the tooth on the flywheel.
'94 Nissan Altima SE, 5spd.
ITEMS FOR SALE
jserrano is offline
post #3 of 6 Old 06-03-2011, 03:28 AM Thread Starter
Thanks for the info. I tried replacing the sensor already, and the code came back within about 50mi, so my money's on wiring right now. Any other suggestions, though?
Robustus is offline
post #4 of 6 Old 06-03-2011, 03:38 AM
Snow... what
05SickSer's Avatar
Quoted: 8 Post(s)
Wiring or an ECU problem. If it isn't that then its something with the flywheel, but my money is on wiring
05SickSer is offline
post #5 of 6 Old 06-03-2011, 06:04 AM Thread Starter
Thanks. Shoulda mentioned earlier, but I tried another ECU too. So yeah - better be the wiring. I'd rather not have to replace my flywheel just to get the CEL out (so I can pass emissions).
Robustus is offline
post #6 of 6 Old 06-03-2011, 05:56 PM
The Don.
Quoted: 5 Post(s)
Yeah, it sounds like a flaky wiring to me as well. Reasoning behind that is that one code basically checks the wiring and the other code checks for inconsistency with the flywheel teeth. If both codes came me back after a DTC reset then it most certainly sound to me like an intermittent flaky wiring.
ITEMS FOR SALE
jserrano is offline
