1996 Altima GXE--How to replace Intake Manifold Gasket - Nissan Forums : Nissan Forum
post #1 of 10 Old 12-06-2011, 01:05 AM Thread Starter
1) When the car warms up the whole car shakes, until I give it gas. Rough Idle.
2) I did the vacuum leak test with carb cleaner and the problem goes away so I have a vacuum leak.
I just need to know how to replace the Intake Manifold Gasket? I am sure this is the cause. Plugs and wires are new.
Thanks!
FYI: Car has over 200K miles on it.
johnfrisco13 is offline
post #2 of 10 Old 12-06-2011, 01:12 AM
Carbon Meet Amber
StanzaDescendant's Avatar
Quoted: 1 Post(s)
Thanks!
Good luck with this. This gasket is not for the inexperienced. Although it is a $15 gasket, it will take hours to do and can be very frustrating. May I suggest examining the PCV system, any and all vacuum lines, and replacing the knock sensor while you have it all disassembled. There are however a few walkthrough's and DIY's in the FAQ.
Originally Posted by cthunder
FX-R Projector Retro v3.0
ES Fog Retro v2.0
DIY Trunk/Chassis Bracing
StanzaDescendant is offline
post #3 of 10 Old 12-06-2011, 01:22 AM Thread Starter
Thanks. Can you please provide me a direct link for DIY's for the 1996 Altima Manifold Gasket Intake Gasket Replacement?
post #4 of 10 Old 12-06-2011, 01:32 AM
Retired 2nd Gen'er.
BeeCee's Avatar
Quoted: 38 Post(s)
They are all in the FAQ forum:
F.A.Q 1993-2001 - Nissan Forums : Nissan Forum
Best way to go about it is get yourself a Haynes manual, and just get in and do it.
The biggest key factors are, taking your time, organzation, having the right tools, and did I mention taking your time?
The Alt.™
1999 Nissan Altima GXE, RIP
2015 4-Door Si
'Members Ride' Thread
Parts FOR SALE! (UPDATED: 9/19/15)
BeeCee is online now
post #5 of 10 Old 12-06-2011, 01:48 AM
Carbon Meet Amber
Quoted: 1 Post(s)
+1.
Take your time. Just remember, if you rush it and damage the gasket or mess up somewhere along the way you won't know until the job is done and everything is back together. And believe me, you will NOT want to pull it all back apart if something is messed up.
Take plenty of reference pictures, separate nuts and bolts and label them, hell even go to a junkyard and practice on a junker if you feel the need to.
ES Fog Retro v2.0
post #6 of 10 Old 12-06-2011, 02:38 AM
The knock sensor is actually really easy to replace from below the car; about 30 minutes of work. Still, "while it's apart" is a good time to do it.
There's a seller on ebay that has knock sensors for $15. Haven't had an issue with the one I got from him, and it's a hell of a lot cheaper than the $170 courtesyparts.com wanted.
lifeofbean is offline
post #7 of 10 Old 12-06-2011, 02:54 AM
Carbon Meet Amber
Quoted: 1 Post(s)
Speak for yourself on that, lol. There's a reason why I have a spare sensor and harness, And it's not for when the one in there goes bad.
ES Fog Retro v2.0
post #8 of 10 Old 12-06-2011, 03:03 AM
Well it only took me about 35 minutes anyway. Front of the car on jackstands, flashlight shining down between #2 and #3 intake runners so that I could see what I was doing, either a 10mm or 12mm wrench, and a small flathead screwdriver. Though I do have kinda small arms...
And some clean boxers for when I dropped the wrench and it bounced off the cable to the starter. Not a fan of sparks inches from my face.
post #9 of 10 Old 12-06-2011, 01:31 PM
Retired 2nd Gen'er.
BeeCee's Avatar
Quoted: 38 Post(s)
Yea, I've been saying for the longest the KS can be done from under the car with no problem.
The Alt.™
2015 4-Door Si
post #10 of 10 Old 12-06-2011, 07:55 PM
Carbon Meet Amber
Quoted: 1 Post(s)
Oh, I know it can be done from underneath. I'm just stating that it can be done easier with the IM out of the way, and you'll have the peace of mind knowing that the KS is new.
ES Fog Retro v2.0
