power steering fluid or ATF Dexron iii - Nissan Forums : Nissan Forum
post #1 of 2 Old 12-11-2011, 10:15 PM Thread Starter
Hi,
I have a Nissan Altima '01. My power steering fluid was pretty low. I wound up pouring in Dexron iii ATF. But now am worried that I should have used Nissan power steering fluid. Did I just mess things up? Or is Dexron ATF okay and I am worried over nothing? I called a few auto shops and they all seemed to think I should have used the power steering fluid and NOT Dexron iii. Any ideas???
justgreene is offline
post #2 of 2 Old 12-12-2011, 05:16 AM
You're fine. Dexron 3 and (most) power steering fluid are similar enough that a lot of cars actually call for ATF in the power steering (GM and Ford in particular).
Never use them interchangably on a Chrysler product though, their power steering systems use some unobtanium moon juice. Hondas are a bit picky as well, but can use Dexron short term.
If you're really paranoid, you can unhook one of the lines to the power steering cooler loop in front of the radiator and let it trickle out, then refill with Nissan power steering fluid (don't do this with the engine running, obviously).
lifeofbean is offline
