2000 Nissan Altima no check engine light - Nissan Forums : Nissan Forum
post #1 of 13 Old 12-29-2011, 11:00 AM Thread Starter
Quoted: 1 Post(s)
Post 2000 Nissan Altima no check engine light
I I recently purchased a 2000 Nissan Altima and discovered when I had to smog check it that the check engine light does not work. It does not come on when you turn the key on, automatic fail. I want to check the wiring pin to pin but the Chilton manual is not specific enough. Any ideas.
Stepside is offline
post #2 of 13 Old 12-29-2011, 01:32 PM
Retired 2nd Gen'er.
BeeCee's Avatar
Quoted: 38 Post(s)
It's probably just the bulb.......
The Alt.
1999 Nissan Altima GXE, RIP
2015 4-Door Si
'Members Ride' Thread
Parts FOR SALE! (UPDATED: 9/19/15)
BeeCee is offline
post #3 of 13 Old 12-29-2011, 10:38 PM Thread Starter
Quoted: 1 Post(s)
All the bulbs and fuses are good.
Stepside is offline
post #4 of 13 Old 12-29-2011, 11:45 PM
Retired 2nd Gen'er.
BeeCee's Avatar
Quoted: 38 Post(s)
And how did you determine the bulb is good?
The Alt.
2015 4-Door Si
BeeCee is offline
post #5 of 13 Old 12-30-2011, 12:14 PM Thread Starter
Quoted: 1 Post(s)
Took out instrument cluster and checked them with a meter. Can see scratches where someone else has checked them before. Also have continuity between the light socket and several pins at the instrument cluster socket.
Stepside is offline
post #6 of 13 Old 12-31-2011, 10:47 PM
Retired 2nd Gen'er.
BeeCee's Avatar
Quoted: 38 Post(s)
True. You could have just took out the neighboring warning light (bulb) next to it, and swapped it into the check engine light spot and see if it illuminated lol, surest and easiest way to see if its truely a bulb issue or not. I would still try and do that.
If still nothing, it might be a contact issue, or you might have to start chasing wires and wiring diagrams. Maybe jserrano will have some input for you as well.
The Alt.
2015 4-Door Si
BeeCee is offline
post #7 of 13 Old 01-03-2012, 05:37 PM
The Don.
Quoted: 5 Post(s)
With the ignition switch set to ON, one side of the bulb should see 12V and the other side should be at ground level. Ground comes directly from the ECU.
'94 Nissan Altima SE, 5spd.
ITEMS FOR SALE
jserrano is offline
post #8 of 13 Old 01-04-2012, 11:10 AM Thread Starter
Quoted: 1 Post(s)
Not the bulb or the instrument cluster. Narrowed it down to the harness or the computer.
Stepside is offline
post #9 of 13 Old 01-09-2012, 10:59 AM Thread Starter
Quoted: 1 Post(s)
Thumbs up
No voltage at the bulb. Found a recent wrecked 2000 Altima on craigslist. Got the computer for $80.00. Light works now.
Stepside is offline
post #10 of 13 Old 01-09-2012, 01:09 PM
The Don.
Quoted: 5 Post(s)
Cool.
Just a note: since 2000, the ECU has to be programmed to the ignition keys in order for NATS to work. Otherwise, the engine will have problems starting up. Just beware of this if you should have starting issues.
ITEMS FOR SALE
jserrano is offline
post #11 of 13 Old 01-13-2012, 09:45 PM Thread Starter
Quoted: 1 Post(s)
I only have one key, no remote.
Stepside is offline
post #12 of 13 Old 01-13-2012, 10:15 PM Thread Starter
Quoted: 1 Post(s)
Check engine light does now work but car still fails for OBD EVAP, OXY SNSR, and OBD EXHST GAS. All 3 fail for not compleat. I assume it is because the the ECU was unpluged and lost its memory. How long does it take to compleat these. IE drive time / start stops. Do I need do do any thing specific to program the ECU to the car?
Stepside is offline
post #13 of 13 Old 01-16-2012, 10:29 PM Thread Starter
Quoted: 1 Post(s)
Car passed smog. Did not drive car long enough and have everything hot enough.
thanks for all your help.
Stepside is offline
