Bad EVAP Purge Valve/Solenoid symptoms? - Nissan Forums : Nissan Forum
post #1 of 5 Old 03-30-2012, 03:20 AM Thread Starter
I bought a used '01 Altima GXE. I've replaced wires/plugs/distributor,rotor/valve cover gasket/fuel filter
When i 1st got it the car had a severe hesitation accelerating. Everything I've done has helped bit by bit. I cleaned the EGR valve, the sensor had lots of carbon on it. I replaced all vacuum hoses visible. I also changed oil and filter.
The car has 212,000+ miles.
Now i have a code 0446 (EVAP purge/vent solenoid circuit condition
I think it means its blocked, or not activating.
I got under the car when it wasn't running and either the purge valve or the solenoid was vibrating like a bee you could hear it and feel it to the touch, i think its stuck open or closed, if its bad, could this cause acceleration to be in spurts and cause hesitation?
I disconnected the battery + & - and it was still buzzing.
Thanks- Racer-X
RacerX309 is offline
post #2 of 5 Old 03-30-2012, 03:25 AM
Carbon Meet Amber
StanzaDescendant's Avatar
Quoted: 1 Post(s)
The solenoid that you're describing should be right on the charcoal canister behind the drivers rear wheel. However their should not always be power to it. The ECU only uses it to do leakdown tests of the EVAP system.
Originally Posted by cthunder
FX-R Projector Retro v3.0
ES Fog Retro v2.0
DIY Trunk/Chassis Bracing
StanzaDescendant is offline
post #3 of 5 Old 03-30-2012, 04:06 AM Thread Starter
Thanks, WHat are the symptoms of it being bad.
post #4 of 5 Old 03-30-2012, 04:27 AM
Carbon Meet Amber
Quoted: 1 Post(s)
Nissan in their infinite wisdom decided to make the valve half metal and half plastic so over time the metal rusts and fills the gap that would normally allow the valve to open and close. If you take it off and find that it does not compress and open freely you can disassemble it, sand down the rust, and reassemble. That will most likely fix the issue. However if the solenoid is bad it will need to be replaced. IIRC they're not that expensive from the dealer, maybe ~$40. Check www.CourtesyParts.com.
ES Fog Retro v2.0
post #5 of 5 Old 03-30-2012, 06:04 AM Thread Starter
Thanks very much,
I will remove the part and try what u described tomorrow.
Can't wait to check it 1st thing tomorrow.
