Originally Posted by StanzaDescendant
Technically speaking any time you change part of the suspension or steering system you should get an alignment or at least have it checked.
Thanks for your input. How about practically speaking? These altimas do not have an upper ball joint. How much does changing a lower ball joint really effect camber, caster, and toe? All things being equal - the ball joint is attached to the knuckle the exact same way the old one was, and I used the same control arm. The old one was very shot (20 years old) and was flopping in the breeze. Interestingly, it was still functional though.
