need help please!!! - Nissan Forums : Nissan Forum
Old 01-22-2013, 03:57 AM
need help please!!!
Hello everyone, I have a 94 nissan altima 2.4L 5 speed the other night i was coming from work and my car started making a weird noise almost a clunking sound but it sounded like it was coming from driver side tire. I pulled over immediately and opened the hood to see my engine smoking and it smelled like burnt rubber. So i pulled spark plug boots out of the cylinders to find that they were melted. I then replaced plugs and wires and it still wouldnt start. I can pull start the car and once i get it between 5 and 10 mph it will crank and run fine i let it idle in my yard for 20 or more minutes with no misfires or anything you can set a lighter on the valve cover and it will not fall over if that gives you any idea about how smooth it runs once pull started. and if i shut it off and crank it immediately it will start. However if i let it sit for more than 2 minutes it will not start back up. i have replaced plugs and wires, ignition coil, and distributor cap and button but it still will not crank. Has anyone ever had this happen? or heard of it happening? please help ive been out of work for a week because of this.
Thank You
Old 01-23-2013, 02:42 PM
jnic116's Avatar
If it cranks over but does not start it may be in the ignition sytem, if it does not crank over than it is in the starting system. So does the engine crank all the time but not start?
The Following User Says Thank You to jnic116 For This Useful Post:
Old 01-23-2013, 04:13 PM
yes it turns over but it will not start unless pull started.
Old 01-23-2013, 05:02 PM
jnic116's Avatar
Pull start meaning popping the clutch right? So it will run that way but will not run using the starter. Sorry for the questions justy wanting clarification of the symptoms.
Old 01-23-2013, 09:35 PM
yea thats correct. however just found a compression tester today
#1 had 60psi
#2 had 30psi
#3 had 0psi
#4 had 30psi
so things arent looking good might just need to get a new/used motor.
Old 01-23-2013, 09:56 PM
jnic116's Avatar
yup, looks that way. but you made sure (sorry to ask) the tester was not leaking?
Old 01-23-2013, 10:35 PM
i sure didnt. i have another friend with a tester im gonna wait til next time i talk to him and use his just to be sure before i pull the old motor out. and thank you very much for helping me
Old 01-24-2013, 06:37 AM
UhOh's Avatar
... don't get caught
I'm with jnic unspoken thought
Originally Posted by James94altima View Post
#1 had 60psi
#2 had 30psi
#3 had 0psi
#4 had 30psi
engine with that low bad compression probably wouldn't run at all, let alone smoothly.
bet there's a test error here - that's should be good news for you.
1997 Altima, 5-speed;
new to me @ 94,000;
now 140,000.
Old 01-24-2013, 06:43 AM
UhOh's Avatar
smoke, smell and melted plug boots says overheat.
did you check radiator coolant level? - when it's cold
Old 01-24-2013, 07:04 AM
The burnt rubber smell (and smoke, if it wasn't steam) points toward a seized accessory on the serpentine belt.
Your water pump is driven by the serpentine belt. Did you lose power steering and/or did the alternator light come on before you heard the noise?
Either way, melted stuff means the engine got more than hot enough to suffer some significant damage. Since you can get it to run with a push start, and have low compression, it's possible that it's fubar enough that the starter just can't spin it fast enough to get it going. But with 0 PSI on one cylinder, it should be shaking bad.
Old 01-24-2013, 04:01 PM
jnic116's Avatar
The melted boot could be a seperate issue, not sure. James when you say you pulled the plug boot off and it was melted, do mean literaly melted? and when you pulled them was that on the side of the road when you first noticed the problem or later when you got it home?
The more info put in an exact timeline is very beneficial when posting the issue on a board for others to assist. This way everyone has a better understanding of the issues to best provide possible avenues to help you. Please keep us informed of the progress.
Old 01-24-2013, 04:15 PM
yes the plug boots were melted and that was the first problem i had. when this happened my temp gauge was at the normal level and the car was running fine. i shut the car off to inspect plug wires and then it wouldnt crank back up. power steering and everything was working fine.
