Great link. I'm assumming that you have the 30 SMT LED (second option). Do you know how the brightness is going to be different from the 11 SMT High flux (first option) since they are the same price? In other words why did you select that particular bulb out of so many other bulbs? Thanks in advance.
I figured the more the merrier, even though that's not true lol jk. I figured I'd get the most even lighting out of that bulb, which would create the most halogen-like lighting field, since I'm putting these in a reflective housing, not just a forward-firing port.
Originally Posted by Sethman408
No chance, I work for a company that designs LED Driver ICs. The LED headlight supply we are currently working on will be driving 24 5W LEDs for headlights.
Ooh, any release date details..?
Originally Posted by jlohcc
Very nice...I'm really liking the LED tail lights. Did you replace the stock wiring harness when you swapped out the low beams?
No, I didn't. I'm still using 55w bulbs in there, not the 70w that most people buy from Hoen.
good website, i see they have LED H11 Bulbs, i wonder if they will be brighter than HID. Headlights & Fog Lights
if you read the top....
High Powered Leds
(Note: Led fog & running lights are for show and color only. Although these are the brightest led fog and running lights made, they are not as bright as halogen bulbs).
I can't wait for someone to make actual LED tails (think Infiniti G) for the fourth gen.
That, and some projectors...
Originally Posted by TyranT11429
Are the led tails light bulbs are brighter than the regular factory bulbs?
Definitely. While they might not appear brighter, they actually throw light further and light up significantly more behind me than the stocks did.
Originally Posted by Sinister
To add to the question above. Is it redder than the stock bulbs? I'd think that it'll look nicer if it has a deeper red tone to it.
Yes, absolutely without question. These put off pretty much the purest red tone out there, so they're red to begin with, plus the red housing helps a bit too.
EDIT: I think the SMT Spider Lights would be really interesting to see too...
Those were the other ones I was going to try, but I was debating on how they would fit and if they'd open all the way in our tail light housing...But if the tower ones look that good I'm probably going to just get those...
__________________ 2007 Precision Grey 3.5L SE with CVT
14.54@96.53mph, 2.29 60' bone stock
hey therupp did u change the reverse nd blinker lights in ur tails or na and if you did u use the same bulb u used for the brake lights and watd you use for the braklights in ur lip spoiler
_____________________________________________
2007 2.5SL altima dark slate w/ black leather, lip spoiler, tech package, and SL premium package, change all bulbs on the inside to white LED's as well as the license plates lights, 8K HID's, hyper white fogs, 20% tint in the front and 15% in the back, tinted tails, se-r style headlights
Planning to get orange led strips on the inside, custom exhaust, intake, 19" gunmetal rims
Nope, I haven't changed either one of those yet. I'm planning on it, but I have to run resistors on the turn signals, which I don't quite know how to do. I'll get around to it though. I'll be using 194 for the backups and 3157 amber for the turn signal when I do.
The lip spoiler is the factory lip spoiler, so it came LED equipped already. I'm going to be installing one of these though: Clear 3rd brakelight
oh ight did u run resistors for the brake light bulb or did u just replace the bulb and why do u have to run a resistor to the turn signal nd reverse light sry im kinda new to all this
No need to apologize, that's what a forum is for anyway, right? Learning.
A resistor basically fools the electrical system into thinking it's getting the same amount of power, since the LED's use a fraction of the power that a conventional bulb does.
The only reason you'd need to run resistors is if the vehicle had a bulb out indicator on the dashboard, which the Nissan's don't, so I didn't have to run one to the brake lights (or the reverse lights if I did them).
You would, however, have to do it to the turn signal bulbs to prevent it from flashing too quickly, better known as "hyperflash". You'll see this on cars that have a turn signal bulb out somewhere in the circuit. The speed of the flash relies on a certain amount of power, so if it's getting too little power, it'll start flashing quickly. This is the same effect if you installed an LED in the car, since LED's use less power.
So, this is where the resistor comes in. The resistor tricks the electrical system into thinking that it's getting the correct amount of power, so the turn signals will flash at the correct speed.
