Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Technical and Specific Interest Nissan Discussion > Member Rides
  #91 (permalink)
Old 03-04-2008, 04:21 PM
TheRupp's Avatar
My VIN starts with a W
WOW that all looks hot... I might be switching plate bulbs although I'm happy with how mine came out. They looked a TOUCH too blue on my old color but the darker color makes a world and a half of difference.
I'm doing the fogs shortly, then the reverse lights and the rear sidemarkers.
Anyone have any suggestions on the rear sidemarkers btw?
I'm thinking these, but I had ones in before that weren't long enough and ended up only being half as bright (if that) as the originals
Or these
Another thing...
The front turn signals... are those more of a reflector-required bulb, or is it something that should project more light forward?
. : The Rupp : .
.: 2007 3.5SE :: Precision Grey :: Sport Package :: CVT :: Höen Xenonmatch Plus Low Beams :. - Traded for:
.: 2008 3.5SE :: Dark Slate :: Premium Package :: CVT :: Garmin nüvi 350 Hardwire :: 20% Tint All Around :. - Gone
.: 2006 BMW 330i :: Sparkling Graphite :: Premium Package :: Sport Package :: 6MT :.
LED: Taillights :: License Plate :: Turn signals :: Backup lights :: Footwells & Cupholder :.
  #92 (permalink)
Old 03-04-2008, 04:37 PM
BlackSentra07's Avatar
The Detailer
Originally Posted by Kango View Post
I used 921 9 LED Super white.
Here is the link. It's the first one on the page.
906 921 Interior Lights
and these for license plate. 4th bulbs down the page in white.
194 168 W5W 2825 Map Led Parking Signal Marker Bulbs
I'm gonna go outside and take a picture of back. BRB
::EDIT::
Love the reverse lights, Question though. Did you notice any light/projecting difference? The only way I'd change out my reverse lights to LED's are if I can project out more light. In a sense, kind of like a headlight in the rear.
My Ultimate Detailing Thread - Tons of Tips, Pictures, and Techniques
2007 Sentra 2.0S - Super Black
Referral: BlackSentra07 (Sentra Owner's needed!)
  #93 (permalink)
Old 03-04-2008, 04:56 PM
Kango's Avatar
I think it's putting out about the same amount of light but the color temperature of these LED's are cooler. Reg bulbs are yellow... so... it might appear as of it's not putting out enough light.
2008 Code Red Nissan Altima Coupe 3.5SE CVT
::Premium Package::Rear Spoiler::Stillen Front Lip::35% Tint::Nokya H11 Hyper Yellow Fogs::LED Brakes, License Plate and Interior::Nismo Cat-Back Exhaust::INJEN Intake::
  #94 (permalink)
Old 03-04-2008, 05:10 PM
The Detailer
I believe these are the ones you got: 9 LED - 921
9 LED - 921
I wonder if these would project more light out. Double the amount, (18), but only 3 on the end. Does anyone know if the housing for the reverse lights are reflective?? If so, I would assume the 18 LED would possibly project more?? (But is it worth $35, instead of $20?
  #95 (permalink)
Old 03-04-2008, 06:18 PM
Sinister's Avatar
Or these
Another thing...
The second option would be the best since it has almost indentical light output as the stock bulb (W5W). The first one will be too dim.
And yes the turn signals are reflector type. I'd recommend getting a longer led bulb since it has more lights on the sides and one or several lights facing foward. If you get a bulb with all foward facing leds two things happen:
1) The leds are usually the 5mm or 10mm type and not smts. SMTs put out a wider beam of light and it looks more uniform.
2) There is a limited number of leds on the bulb that you can place facing foward before the diameter gets to big to fit inside the light housing.
So in conclusion get longer led bulbs with as many leds as possible.
  #96 (permalink)
Old 03-04-2008, 06:48 PM
TheRupp's Avatar
Thanks Sinister
Which bulbs exactly are you running in your reverse housing?
  #97 (permalink)
blackalti's Avatar
the black alti
that looks SIC!!! i gotta get me some of those
http://www.nissanclub.com/forums/nis...-vote-now.html
VOTE FOR ME FOR NISSAN OF THE MONTH!!
  #98 (permalink)
Old 03-04-2008, 07:43 PM
Sinister's Avatar
Thanks Sinister
Call me Ryan. I am running these. They are not as bright as the stock ones, which kind of dissappoints me. I dont know why they dont make them brighter. But Im all over it now.
  #99 (permalink)
Old 03-04-2008, 07:48 PM
The Detailer
Do you think there are ANY LED's that are brighter than stock?? I'm talking about the reverse lights only.
  #100 (permalink)
Old 03-04-2008, 08:13 PM
Sinister's Avatar
As far as the reverse lights go, NO there are none that I know of. And I've search the friggin world wide web. What I do know is that they (the manufacturers) have the ability to make brighter ones. The lights in the car all run on the same voltage anyways. The only way that I know to make it brighter is to fabricate the bulb yourself. Like adding more leds on or running two bulbs on the same base.
  #101 (permalink)
Old 03-04-2008, 08:56 PM
missouriguy1973's Avatar
Reflector, most definitely...The 27 SMT's would probably work well for that since they do have more facing forwards if you would happen to want more light going forward...
2007 Precision Grey 3.5L SE with CVT
14.54@96.53mph, 2.29 60' bone stock
  #102 (permalink)
Old 03-04-2008, 10:00 PM
TheRupp's Avatar
Thanks Ryan
I'm thinking about doing these up front, since the brightest one is up front and there's still some on the sides:
  #103 (permalink)
Old 03-04-2008, 10:39 PM
Thanks Ryan
Whew, $25 a pop though...
  #104 (permalink)
Old 03-04-2008, 10:56 PM
Sinister's Avatar
Rupp I know you want to convert all of the lights to leds but hold your horses on the parking lights and rear markers. The reason is that the light output is almost similar to the stock 194. It's a waste of money. The only color worth converting to is only white or blue.
The first pic is the LED amber 194. Here's a little game. The amber led is in one of the parking lights, either the left or right side. Guess which one is the led and which is the stock.
Amber bulb
LEFT bulb
RIGHT bulb
  #105 (permalink)
Old 03-04-2008, 10:57 PM
ALTIMAX22's Avatar
i used the amber 13 led hpr bulbs from vleds.com for the front turn signals
