Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2007+ Nissan Altima Discussion > *NEW* 2007+ Nissan Altima Discussion
Old 07-23-2008, 04:06 PM
Black_Beauty_Altima
noisy brakes already
My brakes are already noisy and i only have 8200 miles on it? do i need to change the brake pads?
How many miles has your brakes lasted for?
Old 07-23-2008, 04:17 PM
This is a common complaint among us Altima owners. Turning the radio up helps.
Old 07-23-2008, 04:22 PM
ssjones's Avatar
Pull the pads from the caliper, put on a squirt of Anti-squeal. Squeaky brakes typically have nothing to do with worn brakes. Pads vibrating in the caliper. Mine started around 30k. Pads will probably be good until around 80k for my driving habits. Takes longer to get the car jacked up, on jackstands and wheels removed than to fix the squeal. I'll do mine on next tire rotation (every other 5k oil change)
Al Jones
'08 2.5SL/CVT
'04 Silverado Crew-Cab
'96 Impala SS
'02 Triumph Bonneville America
'66 Bonneville Chopper
http://rides.webshots.com/album/561614272bHGHHw
Old 07-23-2008, 04:23 PM
Black_Beauty_Altima
would changing the brakes fix the problem?
How long should the brakes last for?
damn who wants noisy brakes.. this sucks
Old 07-23-2008, 04:30 PM
Changing the brake pads is just going to give you new pads to vibrate and squeal so no, new brakes won't help you.
Follow the advise that ssjones gave you to get rid of the squeaky noise.
My pads are 48,000 miles old and still have about 1/2 the thickness I started with but I'm very easy when driving and braking in my car.
Old 07-23-2008, 04:32 PM
ssjones's Avatar
Not if some anti-squeal isn't applied to the new pads, same squeaking.
Hard to say, fronts pads should last a typical driver 30-40k.
It's quite a simple job, get someone local to help. I did my neighbors newer Impala last night. Dealership quoted him $399 for front brake pads, more if the rotors need replaced. Bought premimum pads at Autozone for $50 and the rotors were fine. Took less than an hour. A few simple hand tools is all that is needed. Some pads are more prone to squeaking than others, same for dust build-up etc.
Old 07-23-2008, 04:38 PM
Black_Beauty_Altima
if i go to the dealership can they fix it
will it be covered under warranty if i dont need new brake pads?
Old 07-23-2008, 04:44 PM
ssjones's Avatar
How many miles on your car? Bet they say you need new pads and maybe rotors, and they aren't warranty items. Put a request on this list for help, surely someone lives near you and can show you how this is done.
Old 07-23-2008, 06:06 PM
Black_Beauty_Altima
i have 8200 miles on the car
Old 07-23-2008, 06:39 PM
Dexion's Avatar
Moderator
Yeah just the way these brakes are designed, they squeak for me on downhill lite braking.
2004 2.5S 10/24/2006 -10/20/2007
2007 3.5SE 6-speed 10/20/2007~
Mods: Fujita WAI | DDM Tuning Slim 35W 6000K H11's | Nismo Catback exhaust | Racingline Y-pipe
Current track data: 60' 2.332 1/4 mile 14.276@100mph
4/24/2009
252fwhp & 230lb-ft torque - more accurate
Old 07-23-2008, 07:26 PM
some good but bad advice here....
Yes some anti-squeak might help, it is NOT the fix. There are 2 TSBs out there for squeaky brakes on 07-08 Altimas. The squeaks are usually under 10mph. The correct fix is take it to the dealership where they will replace the hardware, calipers and pads. If the correct fix was some anti-squeak gel, Nissan wouldnt be shelling out hundreds of dollars fixing every one of these cars.
TAKE YOUR CARS TO THE DEALERSHIP FOR FREE BRAKES
Old 07-23-2008, 09:37 PM
ssjones's Avatar
Why not go for that. 8k on the car, I'd at least ask. If your dealership has a somewhat decent service rep, they'll take care of that issue whether or not it's covered in the TSB. I not sure how reliable the info on this site is, but it listed a TSB for squeaky brakes.
NTB08-057 - Nissanhelp.com
Old 07-23-2008, 10:35 PM
The site is credible... I had the TSB done. The dealership actually "overlooked" the TSB and tried to sell me a $90 service and I pointed out the TSB. What do you know..they found it and did it. There is also a TSB for the rear brakes... I believe it is ntb08-047
Old 07-24-2008, 02:57 AM
Newalt08's Avatar
Herb Gordon Nissan in Silver Spring MD replaced my front pad and my rear pads under warranty. Brakes, Alignments, and other maintenance items are covered for 12/12,000 miles by the manufacture. They even resurfaced my front rotors due to pulsation.
Old 07-24-2008, 03:58 AM
Shihaby's Avatar
my brakes had the same problem, when i took my car to the dealership the guy took one look at the brakes and asked me how the hell did i melt them...
