Maybe no responses yet because ...
you haven't said what
width of rim you are considering.
The factory rims on a 2.0S are 6.5" wide with a 45 mm. offset.
If you are staying with the same width rim, best to try and stay within about +/- 3 mm. of the stock offset.
If you are going with a wider rim, the required offset must be calculated. See:
Wheel Offset Calculator
It's not a case of what offset looks better, or what the manufacturer offers in that style of rim.
It's what offset allows the rim/tire combination to fit
and keeps the contact patch centered as close as possible to stock.
Of course, fit is not limited to "does the rim mount on the hub O.K.?"
It means, "will there be no rubbing or contact at all under every imaginable driving situation?"
It's not a simple exercise, but definitely worth getting your head around it to do it right.
