Aftermarket stereo help/advice - Nissan Forums : Nissan Forum
post #1 of 9 Old 01-01-2017, 05:29 AM Thread Starter
Nissan Fan
Quoted: 1 Post(s)
Post Aftermarket stereo help/advice
So I have a 2014 Nissan Sentra SV with the 6 bose speakers and the navigation with steering controls. I have been looking around and trying to do research but am coming up short handed. I want an aftermarket stereo with apple carplay compatibility but I also want to keep the 6 bose speakers. I got a Pioneer AVH-4100NEX for Christmas but I dont think that works since it only has compatibility for 4 speakers. I was originally going for the Pioneer SPH-DA120. Does anyone have any suggestions on how I could either salvage the unit I got for christmas or should I just try to return it and get the one I was going for?
nak0604 is offline
post #2 of 9 Old 01-01-2017, 07:01 PM
d0ugmac1's Avatar
Quoted: 648 Post(s)
Bose amp works on 4 input (FR, FL, RR, RL). Problem is it wants those inputs differentially at line level (however, many have just grounded the -ve side of the signal with good results...ie using RCA/phono typical connector type). If you have that, you can feed your new HU into the existing BOSE amp and speakers. If you are slightly more 'purist' and I hesitate to use that word in the same paragraph as Bose, then you can buy converters.
Nissan OEM HIDs with Morimoto bulbs/harness, RacingLine FStB & RSwB @ 200%, ETI LED Fogs,
Altima FSMs & Useful posts: Bose Upgrade / Alternator / Bad Ground / Rear Brakes / TPMS Reset /
/ Spurious ABS / Audio Power / ABS Diag / Steering Lock
d0ugmac1 is online now
post #3 of 9 Old 01-01-2017, 07:47 PM Thread Starter
Nissan Fan
Quoted: 1 Post(s)
Im new to trying to put in a radio myself lol so, What parts would I need? I have a wiring harness (70-7552) that I was going to crimp to the harness to the new radio. When you say ground ve what do you mean?
nak0604 is offline
post #4 of 9 Old 01-01-2017, 10:37 PM
d0ugmac1's Avatar
Quoted: 648 Post(s)
-ve == negative (don't know where that comes from...prolly' some old skool crap)
What you need is here, around page AV-149
That will show you the 70-7552 adapter will get you most of what you need from the car harness. Then you need to figure out how to map it to the new HU signals. Check out my BOSE upgrade thread, post the signal output diagram of your Xmas HU and we'll go from there.
post #5 of 9 Old 01-01-2017, 11:37 PM Thread Starter
Nissan Fan
Quoted: 1 Post(s)
Here is the back of the unit
Click image for larger version
ID:	84858   Click image for larger version
nak0604 is offline
post #6 of 9 Old 01-02-2017, 04:24 AM
d0ugmac1's Avatar
Quoted: 648 Post(s)
What I was asking for was this Pioneer AVH-4100NEX
I don't see any PlugnPlay units on the market, but you can chop up any PAC converter that contains the OEM-1 box (ie ROEM-NIS2)...or you can drive your unbalanced line outputs into the amp line ins (cringe) and connect the -ve input to the RCA shield.
post #7 of 9 Old 01-02-2017, 03:48 PM Thread Starter
Nissan Fan
Quoted: 1 Post(s)
Sounds like a lot of jerry rigging to do haha I will have to wait a bit to get the PAC converter, I think youll have to somehow manage to walk me through how to hook it up and everything. I honestly have never messed around with installing a head unit before.
Just out of curiosity the Pioneer SPH-DA120 would that make it a more "clean" install?
nak0604 is offline
post #8 of 9 Old 01-16-2017, 08:31 PM Thread Starter
Nissan Fan
Quoted: 1 Post(s)
Okay, Got it installed and its working great. Just having issues finding a way that lets me get the steering wheel controls working, at least I want to be able to use the button the change the dashboard computer display. Thats the only thing im kinda wanting back.
nak0604 is offline
post #9 of 9 Old 01-16-2017, 09:25 PM
d0ugmac1's Avatar
Quoted: 648 Post(s)
Tell us what or how you did to get it working (ie give back to the community) and we'll see what we can do to help you with the next part.
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN SENTRA / 200SX / SE-R FORUMS > *NEW* 2013+ NISSAN SENTRA Discussion
