Does first gear have a synchro? - Nissan Forums : Nissan Forum
 1Likes
  • 1 Post By d0ugmac1
post #1 of 3 Old 01-09-2017, 04:00 PM Thread Starter
'09 Altima 6speed manual
Altima6speed's Avatar
Quoted: 9 Post(s)
1st gear isn't hard to get into from a stop. But let's say I'm slowing down for a speed bump , about 5mph, from 2nd into 1st , or from a slow 5mph roll in neutral, it can be a little difficult to shift into 1st. Is this normal? I read that double clutching can help go into 1st from a roll. Haven't tried yet. Just curious if this is normal to sometimes have difficult shifting into first from a roll. Should I not be shifting into 1st from a roll, even if it's as slow as 5 mph? In the manual it says the range for 2nd gear is 8mph to 17mph so I don't want to lug the engine by shifting into 2nd at 5 mph.
09 6M/T
Altima6speed is offline
post #2 of 3 Old 01-09-2017, 04:36 PM
d0ugmac1's Avatar
Quoted: 640 Post(s)
My first gear synchro gets more and more temperature dependent every year...as was the one on my old '03SE 5MT. I think the first syncho gets the most use and wears the quickest. When cold...it's sometimes 'hard' to push into gear...so I don't fight it. If I have to slip the clutch a little in second until it warms up then so be it. Sometimes a little waggle in neutral and shift into 2nd beforehand seems to line things up better...YMMV.
Altima6speed likes this.
Nissan OEM HIDs with Morimoto bulbs/harness, RacingLine FStB & RSwB @ 200%, ETI LED Fogs,
Altima FSMs & Useful posts: Bose Upgrade / Alternator / Bad Ground / Rear Brakes / TPMS Reset /
/ Spurious ABS / Audio Power / ABS Diag / Steering Lock
d0ugmac1 is offline
The Following User Says Thank You to d0ugmac1 For This Useful Post:
post #3 of 3 Old 01-09-2017, 05:08 PM Thread Starter
Quoted: 9 Post(s)
alright thanks
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan Enthusiast General Forums > Nissan - Infiniti General Discussion
