Go Back   Nissanclub.com Nissan Enthusiast Forums > Nissanclub.com Technical and Specific Interest Nissan Discussion > Nissan Tires, Wheels, Brakes & Suspension
Google Links
» Search Used Cars
Search for used vehicles by ZIP, please enter Zipcode below:
» Log in
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 05-07-2008, 11:07 PM
Brake Pad replacement
Hello all,
I have replaced brake pads before on a older truck but I now have a 05 Altima 3.5 and need to replace the front brake pads, I have heard that messing around with the brakes on these newer model cars can cause the check engine light to come on and something has to be reset, is this true? Can't I just take off the caliper, use a C clamp to push the piston back in and put in the new pads? Any recommendantions on what pads to buy? I also live in canada so a canadian store would be helpful on where to buy.
Thanks in advanced
Old 05-07-2008, 11:28 PM
mixindamuzic04's Avatar
DJ D-Love
That is a lie. I changed my pads myself...(and rotors)...and didn't have the check engine light to come on. It is just like every other car.
Pads I went with rotors and pads from RPT performance in the vendor group buy (under the marketplace)
I'm happy with them
Old 05-08-2008, 12:16 AM
bt2580's Avatar
'04 2.5SL
Lifetime Supporting Member
It's an easy job, and yes, the 'C' clamp works fine.
Thanks to the following companies for their contributions in product for my car...
www.v-leds.com
See my gallery for list of mods...
http://www.nissanclub.com/forums/vbp...do=view&g=1409
CarDomain
http://www.cardomain.com/ride/3074232
Old 05-08-2008, 12:40 AM
pipeline's Avatar
I can wish, can't I?
Supporting Member
^^ yeah, what he said!
AMSOIL Synthetic Lubricants - PM me what you want and your zip.....
Old 05-08-2008, 01:05 AM
S3AN GOTTI's Avatar
Former Honda Addict
even easier then the c-clamp.
Leave the caliper bolted on. Slide a flat head screwdriver in between the brake pad and rotor. Dig into the pad side more so u don't disfigure the rotor. Then pull the flathead towards the outside of the car repetitively until the piston pushes back. It's like 10X faster then unbolting and c-clamping it. Then toss the old pads, grease up the backside of the new one's and presto.
Same for the back, no twisting, or clamping.
The Altima is seriously easy to change the pads. You'll spend more time bolting and unbolting the rims. hehe...
And the check light thing is some BS disinformation.
06 2.5S | NISM0 - INTAKE, OIL CAP, RADIATOR CAP, BRAKE PADS | 18x7.5 MAXIMA RIMS - 225/45/18 KUMHO ECSTA SPT | 20% TINT | EIBACH SPORTLINE | RACINGLINE FTSB | SE-R XENON HEADLIGHTS |
Old 05-08-2008, 03:11 PM
Ctrl-Altima-Del's Avatar
Prepare to be VQmized
I used Monroe ceramic pads on the front of my Altima with the stock rotors for about a year now. There may be better performance pads out there, but these work well and seem easy on the rotors, are quiet and they dust very little. Canadian Tire sells the Monroe brake parts.
Its a regular brake job, nothing special..but Canadian winters and road salt are killer on brakes. Take the extra time to clean and lube the sliding pins and other contact areas. Inspect/replace the shims, the pad return spring and use some anti-squeal compound on the back of the pads (the Monroe pads come with a tube). That will ensure your brakes stay free and quiet.
'03 3.5SE MT
Avg MPG calculated over last 16214 miles: 26.94mpg
Best/Worst MPG calculated: 32.294mpg / 23.404mpg
Old 05-08-2008, 04:07 PM
RIZAMAN's Avatar
Shaving My Shoulders
Alty brakes are easy as sh*t. NO CEL light.
However you retract the piston though, don't forget to uncap the reservior, and put a rag around it to stop any overflow fluid from dripping out.
You will already have the lower bolt undone to change the pads out (the piston will be "swung" up) - so if you have a c-clamp, use it. Pic is a little cut off, but you get the idea.
Bone stock with Powerslots, Valeo's and tint.
Old 05-08-2008, 04:30 PM
wild willy's Avatar
04-05 Pedal Insert
Won't happen if you turn the C clamp very slowly..
See Wild Willy for your:
*04-05 Dead Pedal Insert Ready
*Custom Brushed Aluminum Dead *5Speed and Auto (Alti & Max)
* Will Make custom Applications
Wild Willy's Pedals
*Bumper Plugs
Garage:
* 91 MR2 31K miles 4 Sale
*02 SE Auto (AT Upper Lower Lux. Grills) 4sale
*04 Honda Odyssey (9.67mpg)
*04 GTO 6MT(Beater) Gone
Old 05-08-2008, 04:33 PM
RIZAMAN's Avatar
Yeah, it never overflowed on me either...force of hablt from my previous vehicles...
Old 05-08-2008, 04:39 PM
wild willy's Avatar
04-05 Pedal Insert
Just have to be patient
Wild Willy's Pedals
*Bumper Plugs
Garage:
Old 05-08-2008, 08:29 PM
S3AN GOTTI's Avatar
Former Honda Addict
I guess it's all in your preference then. I think there is a less amount of force required to retract the piston when it is completely bolted up and you use a flat head. I mean it literally takes like 15 seconds to retract the caliper piston.
But to combine methods: Like use the flat head to retract the piston then unbolt only 1 bolt and swing up would save even more time.
Old 05-08-2008, 08:35 PM
vsupra123's Avatar
Supra Fan/Altima Driver
there is actually a video online where it shows how to replace the pads on our car.
2006 Nissan Altima 2.5S Special Edition
It might be a little modified
Originally Posted by j_archer_69 View Post
I love women that are into cars. Unless they are ugly. Then I don't give a shit.
Old 05-08-2008, 08:49 PM
jumper73's Avatar
^doubt anyone would need video for it. It's almost too simple for the fronts.
Originally Posted by djSER
a friend of mine installed a boost gauge on his WRX..
I was wondering if we have something like that for the SE-R..
Old 05-08-2008, 09:54 PM
S3AN GOTTI's Avatar
Former Honda Addict
You mean this video?
Nissan Altima - Brake Job Part 1 - Free Auto Vehicle Repair Videos at VehicleFixer.com - Find your inner mechanic
Old 05-09-2008, 06:32 AM
UzumakiNaruto's Avatar
^^ hey thats a pretty co0 vid. i may have to watch that again when i get new rotors and pads
Berk v2 Intake, 5000k HiD's, 3000k Hid Fogs,Se-R Tails, s5 clone grill, Vibrant Dual Catback Exhaust,Racing Line FSB , And Slotted Front Rotors
Powered by vBadvanced CMPS v3.0 RC1
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
AutoForums.com is the premier network of enthusiast-owned enthusiast-operated automotive communities.
We operate more than 100 automotive forums where our users consult peers for shopping information and advice, and share experiences and opinions as a community.
Visit AutoForums.com today.
For advertising information, please visit our AutoForums.com website and Contact Us, or send an email message to sales@autoforums.com.
